Have a 03 Disco II HSE7 with 74K that I purchased used. The 60k service was not done. How important is it to change the plugs and wires right now? I'm planned on doing everything else but dread paying the cost of changing the wires (3.5 hours labor).
How important is it, how expensive is you monthly gas bill???????????????
Plugs are a must, plug wires should be done. How mechanical are you, we could walk you thru the process. By the way, plug wire labor on an 03 with secondary air is 5.5 hours I believe, not 3.5. When you get ready to do it, order some 8mm Magnecor wires from Tony at Cerrone's, 650-365-4145, he has a pretty good price on then. You want to use these instead of the junk wires that most auto parts stores have, because they will last and perform much better. Mike |
Mike, I heard you have to take a certain part of the engine off to reach the back plugs, is this true? I don't mind doing the work when it's time but the only spark plugs I've ever changed is my lawn mower. How hard is it?
Do not use Bosch platnium plugs. If you want to, I promise you are better off just leaving what you have in there. They are that bad.
When I was done with her, her bed needed Shamwow sheets! |
Cause Elemental says they are!!!!!!!!!!!!!!!
This has been an on going button for him for years, figures if That is what Rover planned for these engine, there is nothing else that can be used even thought GM ran AC Delco plugs in them for 18 years. Bosch is fine, and is sold at a number of Rover sites, like Atlantic British. Use what you want, I am running Bosch Fushions with great luck. Mike |
I just finished changing mine and wrote it up for my website.
It's NOT a fun job. |
#9 (permalink) | |
'00 DII Member
If you have secondary air...well...that's another issue
'00 DII '07 Toyota Taco War Eagle! |
#10 (permalink) |
Rebuilding Rover
I agree with magnecor plug wires, but in the end plugs are what makes you happy. I tend to agree with Elemental that the old copper cores work great in these engines.
"Only two defining forces ever offered to die for you, Jesus Christ and the American G.I. One died for your soul, the other for your freedom." http://www.wheelinrovers.com/ 91 Range Rover Classic 90 RRC Parts truck 94 Saab gas mileage beater
#11 (permalink) | |
The cheapest place I have found on three continents for Magnecor is, funnily enough, Magnecor US.248-471-9505 It is run by a very forthright fellow from Sydney. All the favorite plugs in the UK for these engines are NGKs. The stock plug used is BPRES. There is a platinum version, BPR5EGP and if you want an iridium tip, the number is BPR5EIX James Last edited by bartell : 06-26-2008 at 10:39 PM. Reason: add tel |
#12 (permalink) |
Rebuilding Rover
never debated 7mm or 8mm but I run 8.8mm accel wires anyways
#13 (permalink) |
Yeah, go ahead and use them. Then in a month, come on here and say"I dont know why I have a check engine light, and my truck runs like shit. I know it can't be the spark plugs because I just changed them."
Mike is a retired Service manager and Advisor. I wasa advsior,manager, ran parts, still am a Double master Tech, with L1 and a instructor. Heres a bet...Search discoweb.org -- for "bosch plugs". Get back to me what you find. If mike could fix a car, he would have made MORE then he did as a manager doing it. THink about it.
#14 (permalink) |
Secondary air....DON'T START ME!
What the hell? All that for a couple of gallons of fuel a decade? Heavy sigh. There is a pair of hoses going across and on top of the coil packs. I'm pretty sure you can't swap them with out them removed. But I'm only an amateur mechanic. But my old man was a television repairman, he's had this ultimate set of tools. I can fix it. |
#15 (permalink) | |
Oh and I know you believe this engine was designed to run on Champions but GM had great results with their Delco plugs. I look forward to seeing if this poster will try the Bosch, would make for an interesting reply a month or so from now, course you will have another good reason to stay away from their use. By the way, I never had a desire to be a wrench and I did make more then you for a number of years. Mike |
| Thread Tools | |
| Display Modes | |
| Swapped Plugs and Wires, got lots of codes | OkieRover | Discovery Series II | 6 | 06-25-2008 07:04 PM |
| I finally replaced my plugs and wires | wimp | Discovery Series II | 10 | 03-09-2007 11:36 AM |
| Plugs and Wires question | brntrout | Discovery Series II | 6 | 11-17-2006 04:00 PM |
| Plugs and Wires | Private Iron | Discovery Series I | 15 | 09-28-2005 06:27 PM |
| plugs, wires, and ???? | plastic | Discovery Series II | 8 | 09-09-2005 02:35 PM |
