How to replace Ignition Coils - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 7 (permalink) Old 04-18-2010, 01:47 PM Thread Starter
Quoted: 0 Post(s)
Hi. I am trying to replace the coils and ignition wires on my Land rover Discover Series II (2004) . The coils seem to be on the back side of the engine wedged between the fire wall and the intake manifold. I started taking off the manifold but it seems to be stuck. The back side of the manifold seems to be what is not coming up. I found the center back bolt and took it out, so thats not it.
Questions.
Do I need to take the manifold off to replace the ignition wires and coils ?
Is there an easier way to get to the coil(s) ?
Is there a hidden bolt I'm missing ?
This started with a failed inspection. Error code P0306 and a check engine light. I replace all of the plugs. The passenger ( right side) plugs were very bad.
newme is offline
post #2 of 7 (permalink) Old 04-18-2010, 02:10 PM
Burncycle's Avatar
Quoted: 0 Post(s)
You don't have to remove the manifold to do it, but it sure is a lot easier unless you are very good with your hands. I believe there are 6 bolts holding the manifold itself and there may be two more very small bolts holding the coil pack bracket on the manifold.
2001 DII, 2" Rovertym lift with OME shocks, D1 Cdl linkage, La Ruta My roof Rack, 4 Off road lights, Custom exhaust no cats and flowmaster 40 series, Trimmed front bumper. [Very sadly sold
2010 F150 XLT 5.4L V8
stock for now... Towing my Rover wherever its little heart desires.
Burncycle is offline
post #3 of 7 (permalink) Old 04-18-2010, 04:34 PM
Quoted: 0 Post(s)
I'm trying to get the plenum off too. I believe mt 03 needs wires. It seems that the plate which has the coils mounted on it comes up over the edge of the plenum and stops it coming off. I have removed the SAI mount bolts mentioned above with no luck. There were pictures posted here at one time by a user known as 007 but the links don't function. He claimed to have good images of the process.
63rover is offline
post #4 of 7 (permalink) Old 04-18-2010, 05:01 PM Thread Starter
Quoted: 0 Post(s)
I couldn't get the manifold off, so I just put it back together again. It popped the P0306 and P0300 codes within the first 6 miles. I can feel it bobble once in a while. I'm looking at the space back there. I can't even get more than one finger onto the coils back there.. Suggestions ? Am I missing something ? Can I get the wires off without actually seeing them ?
newme is offline
post #5 of 7 (permalink) Old 04-18-2010, 07:19 PM
hafaday's Avatar
Quoted: 0 Post(s)
the coil pack is kinda f'ed up. IIRC there are 4 bolts that hold the coil pack in place, 2 upper bolts that go into the upper intake and 2 in the lower. have to look down to see them.
the u/i (upper intake) has to come straight up about 1/8", the lower has 2 dowel pins (located internally) to line up the u/i when installed. this is hard to do with the hard heater pipe lines in place (on top of pass. valve cover). you can remove or pull up on u/i at a slight angle and pull u/i out to the right (driver side).
be careful, alum dings easy. don't wanna mess up the machined surfaces.
01 d2
Bill H.
The Rave on pdf's.
hafaday is offline
post #6 of 7 (permalink) Old 04-18-2010, 07:22 PM
RAYMAN985's Avatar
Quoted: 0 Post(s)
it is a big pain in the butt. i replaced my: valve cover gaskets, upper intake plenum gasket, magnecore wires and ngk plugs, and throttle heater plate. even with the upper intake off, it was a huge pain!
i dont see how it would be possible to change coil pack or wires without having that upper intake off. mine has that stupid hardline back there as well, for the secondary air, which made pulling out the coil pack a pain too
RAYMAN985 is offline
post #7 of 7 (permalink) Old 04-19-2010, 05:55 AM
BowRat's Avatar
Quoted: 0 Post(s)
Follow the instructions on this post:
Replace Wires Without Removing IM - Land Rover Forums - Land Rover Enthusiast Forum
Ignore your brain when it tells you several times "that's not possible", I had to ignore mine several times during the 3-hour journey to get this done!
It wasn't mentioned anywhere, but the biggest revelation that I had during the process was to use a stepladder to gain better access to the wires. The next challenge was getting my arms down in there, but that's another story!
Good luck - it IS possible!
'03 DII Chawton White
BowRat is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Key spins in ignition switch .. replace or spay WD40? 702a88 Discovery Series II 3 02-24-2010 09:55 AM
What are the numbers for the ignition coils canadianDisco2owner Range Rover P38, Mk III and Range Rover Sport 1 05-04-2009 12:50 PM
'90 RRC..key broken in ignition...have to replace switch....input? Ken McGlynn Range Rover Classic 1 07-07-2008 08:42 PM
Ignition coils. Avalera1222 Discovery Series II 1 03-27-2007 03:15 PM
what coils to get ? greekdisco Discovery Series II 13 10-17-2006 03:45 PM
You may post new threads
You may post replies
