Idiotically i went off roading by myself without any equipment in a stock discovery. when i got stuck in some mud, the only wheels that would spin, were the two that were in the mud. I had two perfectly fine wheels on gravel, but they werent spinning. The thing I dont get is why the 4 wheel drive didn't power the only wheels with traction? I thought the whole purpose of 4 wheel drive on a vehicle was to provide power to wheels with traction, when other wheels don't have traction. Am I missing something here?
You have a CDL? What year is your truck? If your CDL isn't engaged then all the power is going to be transfered to your tires that are spinning.
If it makes you feel better I got stuck in 2 feet of hard packed snow and my tires dug in. By myself, no shovel...three hours later of digging with a scrapper and a tire iron and I was out!
2000 Land Rover Disco II My Disco's a bush truck. Wtf to I care about scratches?
Engaging CDL only splits the power front to back. I bet you had one side on mud and one on gravel? ETC should have gotten you out of that. 4WD is only truly 4WD when you have front and rear lockers.
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc. '91 RRC, bone stock |
Yeah, if the ETC was operating properly, you should have had no problem getting out of the above described situation. No CDL needed, with how you explained it. I have never gotten close to stuck when one side was on hard pack. Heck, with proper brake modulation to keep the etc locked up, if one wheel has traction, you can pull out of most stuff if you've got good M/T's and aired down.
"In certain places, at certain hours, gazing at the sea is dangerous. It is what looking at a woman sometimes is." - Victor Hugo Originally Posted by Elemental Some guys play hard to get, I play hard to want. |
You have to know how to drive with the CDL and or ETC, it isn't a sure fire thing if you are just out trying to power thru the mud, you need to let the system allow you to crawl out of the mud.
Mike |
"PLH"
Thats happened to me a number of times. All i did to get unstuck was to turn off the engine and whenever you turn it back on you gun it and all your tires will spin.
"You can never be old and wise if you were never young and dumb" |
#9 (permalink) |
well i have an 03 no CDL
two wheels on one side were in mud about 4 inches deep. the other side on the gravel. i couldnt believe i got stuck and i had to ask some random guy with an s10 to pull me out. |
#12 (permalink) |
2002 Discovery II SE
I've experienced similar retardedness with no CDL.
However, the key to the ETC/Traction Control is that you have to keep your foot into it at all times. Not alot, just enough. I accually have footage I took awhile back of me trying to cross some shallow ruts. The purpose of the excercise was to see if the ETC could work it out. You can visually see the computer working it out. |
#13 (permalink) | |
Mike |
#14 (permalink) | |
Bet that's the problem, the 03 had the first really major improvement when it comes to the ETC. MIKE |
| Thread Tools | |
| Display Modes | |
| If your key gets stuck in the ignition, do this | etischer | Tech & DIY | 2 | 08-06-2007 11:44 AM |
| Tape stuck in radio-Mode stuck on “tape” | Kris | Range Rover Classic | 2 | 01-28-2007 09:03 AM |
| 88 ways to tell you're stuck in the 80's | apbtpetey | The Lounge | 35 | 01-20-2006 11:23 PM |
| Engine seems stuck between 2500-3000 RPM | VanAlex | Freelander / LR2 | 5 | 08-18-2005 05:33 AM |
| Stuck and Dissapointed | disco96 | Discovery Series I | 10 | 07-08-2005 10:45 AM |
