I have a K@N air filter, I pump my wheels up to 40 PSI. And when I am in stop and go traffic I keep my RPM's at or below 2000 RPM. I also cost from one light to the other. I do not do the 2 block drag race. And when I get on the high way I take my time if I can. I rarely go over 60 MPH now days. I hope this will help.
Ditto on the air filter, tires, and driving technique.
How are your spark plugs and fuel injectors? They may need some attention. Another possible improvement you might try is engine oil. Lower weight oil will reduce oil flow resistance compared to a thicker weight, and help your MPG. Using a quality synthetic oil may reduce engine friction over petroleum based oil, also increasing engine efficiency. These benefits can also be applied to your drivetrain as well. Less resistance=better fuel economy |
i get 9 mpg with conservative driving. That's what 155k, 33" m/t's, and a 2" suspension lift with do to your 3.9L on a 95 disco. If anyone has any tips on better fuel economy, other tan K&N filter, please let me know, they would most likely be worth the investment.
AHO Rugby, a drinking club with a rugby problem. www.ahorugby.net "My experience through life has convinced me that, while moderation and temperance in all things are commendable and beneficial, abstinence from spirituous liquors is the best safeguard of morals and health." - Robert E. Lee |
I was getting around 9mpg on a consistant basis.. I cleaned out my radiator (was clogged with ton of mud from dropping into a hole), cleaned my K&N [pretty dusty from the conditions i go in].. and most importantly, turned off my A/C.. last tank I had, I got 11.8mpg.
I normally get 15.5 to 16 on day to day driving and have gotten 17 on long trips. Thats running 255/70 R16's, 2" lift and ARB brushbar and winch. I had to apply a correction factor of about 3.5% for the larger tyres. I used my GPS on a 50 mile stretch of highway and compared it to my odometer.
I normally burn 91 octane though I have to make it my self by blending 1/2 tank of 89 with 1/2 tank of 93. I used to burn the cheap stuff but after replacing the engine I figured it was a small price to pay. I don't think the gas had anything to do with the cracked block but why take any chances. I put the K&N filter back on last week but dont think it really makes any differance. I run full synthetic oil, keep the tyres well inflated and drive like I have a bowl of goldfish on the seat next to me. i.e. no fast starts/stops. Greg H |
#9 (permalink) | |
2006 Range Rover Sport HSE Rimini Red 2002 D2 4 SALE 2001 D2 CDL ![]() 1998 D1 ('Henry' Sold 05/05 Bought Back 01/06 Retired) 1988 RRC SWB ('Silver Bullet' Retired 05/98) |
#10 (permalink) |
4x4 Adventure Gear
I run 285/75/16 BFG ATs, 3" lift, winch and other accessories (some of my accessories are stronger than stock but lighter). I get 12.5 mpg.
For those of you getting around 10 mpg make sure your O2 sensors are good.
John C 1996 DI - 3" AG lift 1995 DI - Scorpion Racing Extreme Kit 1991 RR - parting out (few parts left) 1990 Kawasaki KL650B Tengai 1989 Kawasaki KLR650 |
#11 (permalink) | |
#12 (permalink) |
Use premium.. use super/ultra/etc.. at the gas station..
Money Wise: Figure a tank (on a Disco2) is 23 gallons.. estimate you fill it once a week.. there is generally a $0.20 difference between regular and premium.. so thats an additional $4.60/week, or an additional $239.20/yr. Tech wise: your truck should have a knock sensor which will adjust to the lower octane, but therefore, it will adjust the ignition to compensate for the fuel octane.. but by doing that, you'll be running at lesser performance (read, less mpg). So, A) it's not a signifcant amount of savings, especially when you compare it to how much it'll cost to get a new engine if anything does go wrong, and B) you'll be getting lower mpg's therefore almost negating the cost difference. Will it work? Yeah.. I know some people who have been running regular for 100k+ miles on their discos w/o problems.. but personally I wouldnt. |
#13 (permalink) | |
#14 (permalink) | |
Wheeler
#15 (permalink) | |
I have been using PLUS gas, typically I got the high test. I hope I am not ruining my truck. What would ahppen if I used regular?
"Animals are reliable, many full of love, true in their affections, predictable in their actions, grateful and loyal. Difficult standards for people to live up to." ~Alfred A. Montapert~ |
