Interior plastic wrap - door panel - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 15 (permalink) Old 05-26-2010, 08:51 AM Thread Starter
Quoted: 0 Post(s)
passengers side window is stuck in the down position so i popped my door panel off but was wondering if there is a good/easy way to deal with the plastic layer that seals the inside of the door.
I don't want to cut through it but pealing it around the door doesn't seem like a great option either.
Any advice from someone with some experience in this department would be much appreciated.
Thanks a bunch
texasttk55 is offline
post #2 of 15 (permalink) Old 05-26-2010, 09:31 AM
Quoted: 1 Post(s)
Cut it and tape it with clear packaging tape. You can get away with an L cut large enough to fit your hand through.
Bosbefok is offline
post #3 of 15 (permalink) Old 05-26-2010, 10:09 AM Thread Starter
Quoted: 0 Post(s)
ok so i cut the plastic back and can see that there is a piece of a white roller in the lower tract.
the window motor is working but there is no movement at all. Is the white plastic roller the culprit or should i be looking for something more?
post #4 of 15 (permalink) Old 05-26-2010, 10:35 AM Thread Starter
Quoted: 0 Post(s)
so i did a little research and it seems that i'm going to have to replace the passenger side regulator.
im going to go ahead and order the part unless someone has some better advice.
post #5 of 15 (permalink) Old 06-03-2010, 03:45 PM Thread Starter
Quoted: 0 Post(s)
Recently I have taken out the old passengers side window regulator and am in the process of installing the mew one. My question is does the electric motor not have any mounting hardware on the back of the regulator plate? It looks to me like the only thing holding the motor to the regulator is the pressure from the motor gear on the toothed tract.
Is this correct or am I missing some backing hardware? The three Torx screws just seem to be sitting in the plastic housing of the electric engine with no nut securing them to the actual regulator plate.
post #6 of 15 (permalink) Old 07-15-2010, 07:32 PM
rwhitmo04's Avatar
Quoted: 0 Post(s)
Hey texasttk55, I recently removed the door paneling on my '04 Disco to try and see why my window is acting up. When the window is going down, it makes a loud pop, almost like it is off its track. Did you find anything when working on yours that might help me before I tear into the moisture barrier?
rwhitmo04 is offline
post #7 of 15 (permalink) Old 07-15-2010, 07:49 PM
DiscoDream2's Avatar
Quoted: 1 Post(s)
Either the motor has taken a dump or the little white plastic wheel has cracked, broken or fallen off completely. You can cut through the plastic and tape it up later. Go ahead ,... you can do it! I dare you!
The motor is held in place via 3 #4 torq screws that run through the regulator and into the motor. I bet you have the motor on the wrong side of the regulator, upside down or backwards. It's the only way it can go.
To test: Take the regulator and attached motor out. Detach it from regulator and run the window from the switch. If it works it's good. Put it inot the regulator and test again. sometimes it binds. Often as a result of the little white wheel going so it sips out of the track and jacks up.
If the switch is good it is usually the motor and wheel issue.
DiscoDream2 is offline
post #8 of 15 (permalink) Old 07-15-2010, 10:32 PM
03discoveryrover's Avatar
Quoted: 0 Post(s)
Rip Thr Plastic Of And Go Buy A Roll Of Temp. Carpet Protector Film
03discoveryrover is offline
post #9 of 15 (permalink) Old 07-16-2010, 04:40 AM
rwhitmo04's Avatar
Quoted: 0 Post(s)
Thanks for the tips, I'll see if I can get to it this weekend.
post #10 of 15 (permalink) Old 07-16-2010, 06:25 AM
AZ Disco
Quoted: 0 Post(s)
I have the same problem with my '04 disco that I just bought last month but I wish the roller was still there. If your window moves up and down a fraction of an inch with a sideways tilt then your problem is not the regulator. The piece of metal the roller fits on has got caught in a hole in the top bar of the window lift assembly. All you have to do to free it is get a friend to operate the window while you stick your hand up to free the metal piece the roller sits on and the window will roll down for you to fix. If you can't get the roller back on cover the hole with some duct tape and your window will still work fine.
p.s. watch your hand doesn't get caught in the window when it is coming down.
Alan
'04 Discovery
Jul '10 265/65/R16 General Grappler AT2's
Aug '10 Replaced water pump and fan.
aohanlon is offline
post #11 of 15 (permalink) Old 07-16-2010, 07:03 AM
Quoted: 1 Post(s)
That is the problem, you can get a used one from one of the parts guys in the classified section they are $$$$$ new.
post #12 of 15 (permalink) Old 07-18-2010, 05:02 PM
rwhitmo04's Avatar
Quoted: 0 Post(s)
So I just tore through the moisture barrier and rolled my window down only to realize that it no longer makes a popping noise... The motor sounds like it is about to go, but the popping is gone. I don't want to put the paneling back on only for the noise to return. Should I go ahead and pull everything as suggested?
post #13 of 15 (permalink) Old 07-19-2010, 03:12 PM
rwhitmo04's Avatar
Quoted: 0 Post(s)
The white plastic wheel was the culprit. The regulator appears to be bent as well. Thanks for the help.
post #14 of 15 (permalink) Old 07-19-2010, 04:08 PM
rwhitmo04's Avatar
Quoted: 0 Post(s)
Is there anywhere that I can buy just the white plastic wheel, or am I going to have to replace the whole regulator?
post #15 of 15 (permalink) Old 07-19-2010, 07:34 PM
Quoted: 1 Post(s)
Gotta replace the whole regulator.....the wheel is riveted on there. I have tried a few different ways to remove the wheel alone, but the rivets would be too much trouble on the replacement wheel. Some one may want to McGyver one but not me. You can order a regualtor from the used parts guys in the classified section. Not too expensive without the motor, then use your motor on the ordered regulator.
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Plastic fuel door latch/clip Original Junior Discovery Series I 10 10-21-2011 07:03 AM
Interior door handle won't open door Rycymru Discovery Series II 0 03-31-2008 07:41 PM
What is the best interior cleaner and preservant for plastic/vinyl? wflorence Range Rover P38, Mk III and Range Rover Sport 10 05-30-2007 10:30 AM
cargo door panel, drivers door panel jed Discovery Series I 2 02-22-2007 04:59 AM
Interior Trim Panel Attachments allende Series Land Rovers 0 03-19-2006 07:02 PM
You may post new threads
You may post replies
