Old 08-14-2006, 06:29 PM   #1 (permalink)
drum655's Avatar
Default knocking underneath
i hear a strange knocking noise under my truck and it sounds like it could be coming from the transfer case. could this be where it is coming from, and is that a sign that i need to change the lube in my transfer case? please help!!! i don't want this to grow into a largewr problem!
2001 Disco II SE w/CDL
~Equipe 4x4 Winch Bumper
~Custom steel rear bumper
~Equipe 4x4 steering skid and radiator skid
~RTE rocksliders
~QT services front and rear diff guards
~2" RTE lift
~265/75 r16 Federal Couragia MTs
~Superwinch X9
~Safety Devices Roof Rack
drum655 is offline   Reply With Quote
Old 08-14-2006, 06:34 PM   #2 (permalink)
When do you hear the noise, hot/cold or idle or while driving?
Old 08-14-2006, 06:43 PM   #3 (permalink)
drum655's Avatar
the noise is more apparent when the engine is warm/hot, and it is most noticable at idle and at very low speeds...any ideas?
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 08-14-2006, 07:25 PM   #4 (permalink)
Think CATS. Sounds like you did something to up set the cats and killed one or both.
Before you replace them, find out what fired up the cats and turned it into a bag of marbles, like wires. plugs, fouled injectors, heagasket, that sort of stuff.
Old 08-14-2006, 07:37 PM   #5 (permalink)
drum655's Avatar
to me it just does not sound like what i imagine a busted cat to sound like....its almost a rhythmis knocking....how can i tell? i banged on the cats the other day and nothing rattled and i havce no check engine lights
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 08-14-2006, 09:10 PM   #6 (permalink)
Crawl under the truck while it is running and rattling and see where it is coming from.
