Old 05-25-2008, 03:50 PM   #1 (permalink)
Ghost Face Killa
kkahao1's Avatar
Default L Shaped Hoses 03 - Disco Mike
Mike, the hoses can be located by following the air intake to where the yellow sticker is right b/f the intake manifold. Directly at the yellow sticker there is a L-shaped hose and an identical one on the other side. Both of these on my disco have small cracks where they connect to the intake manifold but they are minimal and do not go out past the hose clamps.
P.S. how do you tighten or loosen those hose clamps? I'm used to ones that require a screw driver.
I'll add pictures of the oil on the top of v.cover on driver side and the leaky valve cover on the passenger side when I get a chance.
Thanks
l-shaped-hoses-03-disco-mike-112_0301_mid-lux_sport_with_utility_pl-2003_land_rover_discovery_4.6-top_engine_view.jpg
kkahao1 is offline   Reply With Quote
Old 05-26-2008, 06:35 AM   #2 (permalink)
I am old, not necessarily blind but on a good day, I couldn't see what your talking about on that thumb nail picture.
E-mail me something I can see.
Yhanks,
Old 05-26-2008, 08:42 AM   #3 (permalink)
Ghost Face Killa
kkahao1's Avatar
Sorry thought you could click to enlarge it.
Old 05-26-2008, 08:50 AM   #4 (permalink)
Ghost Face Killa
kkahao1's Avatar
Default 4.6 L shaped hoses
Mike, try these. Hoses located directly above dipstick. The large 1-2inch diameter hoses that connect to the air intake and intake manifold
l-shaped-hoses-03-disco-mike-lr-4.6.jpg  l-shaped-hoses-03-disco-mike-lr-4.6-2.jpg
Old 05-26-2008, 09:04 AM   #5 (permalink)
Call me.
Old 05-26-2008, 10:43 AM   #6 (permalink)
Roverhound's Avatar
If you look at them it will become apparent how they can be taken apart.
You can use a screwdriver to pop them loose and a pair of slip joint pliers to put them back on if you want to reuse them.
It just doesn't matter.
Thanks Disco Mike - Problem Solved! helievacpilot Discovery Series II 0 04-11-2008 07:34 PM
What does Disco Mike do when he has a problem? plastic Discovery Series II 21 04-11-2007 05:28 PM
Thanks Disco (moderator) and Disco Mike bobthebuilder Discovery Series I 13 11-19-2006 10:15 PM
Welcome back Disco Mike? BIRD Discovery Series II 0 05-06-2005 07:40 PM
