Land Rover Discovery II Engine noise. *PLEASE LOOK!* - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 25 (permalink) Old 07-26-2010, 12:12 PM Thread Starter
Quoted: 0 Post(s)
my aunt's discovery is making a gear whine noise when at around 2k rpm and above. is this normal? She needs to know before she goes back home in a couple days. so Please help! Thanks!
Jesse94 is offline
post #2 of 25 (permalink) Old 07-26-2010, 01:09 PM
Tom Sheppard Wanna Be
Quoted: 0 Post(s)
For the record we have two Discoveries, 1996 and 1999 and neither exhibit any "Gear Whine'. The only whine I ever hear is my wife wanting me to stop for something to eat...
The only time I had any whine in the engine room, it was a bad bearing on the alternator. You can take a long shank screwdriver, press the plastic handle next to your ear and touch the different rotating parts; AC, Alternator, steering pump, etc and hear pretty reliably which one is making the noise. For the bits that you can't safely reach, while keeping all your body parts safely clear, get a 3 or 4 foot piece of small diameter rubber hose. Fuel line is great and just hold one end at ear other endnear the component you are checking. You can isolate sounds pretty quick. We used the rubber hose method, to synochronize the three side draft carbs. on our MGB.
Good luck...
HIS: 1996 Discovery Series I, "Saudi" grille, OME 3" lift springs, OME Stabilizer, LR Diff lock, Bilstein shocks, ARB front bumper, WARN M12000, Safety Devices roof rack, LR rear ladder, 4 Hella 4000's, LR OEM driving lights, best of all LR cup-holders.
HERS: 1999 Discovery Series II, OME Stabilizer, LR Brush bar, LR rear ladder, LR Cup-holders. Hella 500's.
Ours: ARB 45QT. Cook Partner, 3 burner stove, REI Camp Kitchen.
Voyageur is offline
post #3 of 25 (permalink) Old 07-26-2010, 01:22 PM
Quoted: 0 Post(s)
Is this while driving or standing still?
Diffs can whine, or the transfer case.
Bosbefok is offline
post #4 of 25 (permalink) Old 07-26-2010, 01:26 PM Thread Starter
Quoted: 0 Post(s)
Driving And standing still.
Jesse94 is offline
post #5 of 25 (permalink) Old 07-26-2010, 01:28 PM
Quoted: 0 Post(s)
Ok so that excludes diffs and TC, do as Voyageur says.
Those idler pulleys and tensioner pulley can also whine when they go bad.
Keep your fingers and other body parts out of the fan and serpentine belt - unless you're not attached to them.
Bosbefok is offline
post #6 of 25 (permalink) Old 07-26-2010, 01:35 PM
Quoted: 0 Post(s)
Bosbefok...
Holy Crap! I thought you were talking about using my "Hose" method... LMAO!
Voyageur is offline
post #7 of 25 (permalink) Old 07-26-2010, 01:56 PM Thread Starter
Quoted: 0 Post(s)
I just tried the screw driver on the alternator. Doesn't sound any different than my dad's truck's alternator. So I'm gonna rule that out. any other suggestions?
Jesse94 is offline
post #8 of 25 (permalink) Old 07-26-2010, 02:10 PM
Quoted: 0 Post(s)
Anything that turns in that engine bay can whine, there's plenty there.
Could it just be the cooling fan that's kicking in? Check the electric fan as well, the one behind the front frill.
Bosbefok is offline
post #9 of 25 (permalink) Old 07-26-2010, 02:13 PM
Quoted: 0 Post(s)
Originally Posted by Voyageur View Post
Bosbefok...
That would be hectic
Bosbefok is offline
post #10 of 25 (permalink) Old 07-26-2010, 02:14 PM Thread Starter
Quoted: 0 Post(s)
Tried everything I could reach. the rubber hose trick didn't work for me. there is a pretty bad clunking noise in the rear passenger side of the motor. it isn't rod knock. sounds more like chunks of metal in between gears.
Jesse94 is offline
post #11 of 25 (permalink) Old 07-26-2010, 02:14 PM
Quoted: 0 Post(s)
Other Rotating Equipment
Do the same on everything else that is spinning when the engine is idling. Get a piece of hose, it's better for access. Serpentine belt pulleys, (Idler is one) AC compressor, Power steering pump, Water pump is too close DON'T check that. Do you have secondary air?
See if the sound comes and goes when you turn the AC compressor on or off.
Make sure power steering pump reservoir is full of fluid. Low fluid sometimes equals "Whiney" noise.
Also make sure there is nothing touching the cooling fan shroud or aux. cooling fan blades. Every once in a while an object from the road hits something in the engine compartment and busts a hunk out of some plastic part. A piece of broken plastic, rubbing on a spinning part, works like a phonograph record.
Good luck...
Voyageur is offline
post #12 of 25 (permalink) Old 07-26-2010, 02:17 PM
Quoted: 0 Post(s)
Jesse... I sent my last reply before I read your last post.
>>>sounds more like chunks of metal in between gears. Have a qualified mechanic look at it right away. I wouldn't drive it any farther than I had to. That is potentially a very bad sound.
Voyageur is offline
post #13 of 25 (permalink) Old 07-26-2010, 02:21 PM
Quoted: 0 Post(s)
Seriously? If it sounds that bad then I would not run the engine and have it looked at by a mechanic.
Bosbefok is offline
post #14 of 25 (permalink) Old 07-26-2010, 02:27 PM Thread Starter
Quoted: 0 Post(s)
it isn't really That bad, but it is noticible if you have your head down in the engine. and it made it from north georgia to central florida just fine so I don't think its too serious.
Jesse94 is offline
post #15 of 25 (permalink) Old 07-26-2010, 02:36 PM
Quoted: 0 Post(s)
Whine
If it's really high pitched it could definitely be an idler pulley. Mine had a really high pitched whine...until it froze, unscrewed itself, and allowed the serpentine belt to get caught in the fan. Not a pretty picture.
If it's coming from the engine compartment, try to find the source. Remove the serpentine belt and spin all of the components. These rovers do whistle and whine even when everything is OK, but anything out of the ordinary will not fix itself and could cause trouble down the road.
GuyD is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
2000 Land Rover Discovery 2 squealing noise with knock going into drive soldondisco General Land Rover Discussion 3 09-05-2014 05:22 PM
Discovery Transmission and Transfer Case 1996 Land Rover Discovery 4.0 Rangie Mark Land Rover Parts and Accessories 4 09-16-2011 10:31 PM
engine noise Discovery II jdeclet Discovery Series II 6 07-11-2010 11:42 AM
Parting out a 1995 Land Rover Discovery I and 2001 discovery II dod Land Rover Parts and Accessories 15 10-27-2008 01:55 PM
2003 Land Rover Discovery SE7, Land Rover Certified Warranty (CPO) 2010/86K & DVD BWBW Land Rover Vehicles 2 10-04-2007 06:17 PM
You may post new threads
You may post replies
