I think I ran into the same issue that Mike is referring to. I had a leak that was dripping down from the rear of the block, down onto the exhaust. Further investigation found it to be coming out of the gasket on the underside of the throttle body, then running down the valve cover to the rear of the engine. Replacement part from Atlantic British is about $15 and is called the Throttle Body Heater Plate Kit MGM00010KG.
Mike - is that the same part that you refer to as the Valley Pan Gasket? |
