Old 06-30-2008, 12:30 PM   #1 (permalink)
Question Leaky Transmission/ Maintenance Guide
All right all I have a 2001 Disco with the Diesel TD5 engine auto transmission. European Specs. Love the car but I noticed a oil spot under the car. I got on my creeper and checked it out.
Good news it is not an oil leak/ my oil is dark and needs to be changed. Bad news is that it looks like it is the transmission or gear/box right behind the engine(the fluid looks more like gear oil than trans fluid light brown vs red). It looks like it has dropped about half a pint (just guessing)
Ok I don't have a service manual or even owners manual b/c the manual is written in German.
My questions:
1. How do you check the fluid and add more? Is it sealed?
2. After exploring the bottom of the car I could not find an oil filter? Where the heck is it?
3. Can anyone reccomend a good service manual or download for this vehicle? I consider myself pretty good with a car but I am looking at this thing and feelin really stupid right now.
Any help would be appreciated
luc3504 is offline   Reply With Quote
Old 06-30-2008, 01:49 PM   #2 (permalink)
If it is the t/case, there are no filters. The drain plug id a 1/2" plug on the bottom of the case, the fill/inspection plug is on the back side of the t/case, up high partially hidden by the e-brake drum, same type of plug as the drain plug.
Old 07-01-2008, 10:37 AM   #3 (permalink)
Should have explained further, I meant the engine oil filter.
I am thinking it is transer case. but is just seems like it is in a strange location
Thanks
1995 LWB Transmission shifting problem serge9444 Range Rover Classic 3 11-26-2007 12:26 AM
transmission problems scotth Discovery Series II 1 04-20-2007 11:06 AM
Transmission Service Kit AAXD Discovery Series I 7 11-17-2005 09:36 AM
RR maintenance suggests (oil & trany) glenncof Range Rover Classic 4 09-29-2004 03:36 PM
