My Friend got his Disco worked on and the Mechanic said that it had some lifter noise.... Hes got 108k miles. He Told me that its apparently not a big deal and that ALL Discos will do it. Apparently is ok to just leave them ticking and it doesnt do anything to your engine.
Is this true? I havent heard of anything like this before... I know My 2000 Bmw has a slight ticking sound but the Dealer said its "Normal" The reason I wanted to know is Because MY Disco has around 85k miles and If I start to get a lifter noise what should I do? Or Better yet.. My friend doesnt like the fact that his lifter is making noise and he also wants to know what he can do? ![]()
Disco Madness at its best |
Lifter noise in any engine, except with solid lifters, is not normal and is an indicator of wear, be it either in the lifter or the harden surface of the cam.
I would suggest you consider cleaning out your engine and then doing a oil pressure test to confirm you are getting good oil flow. Mike |
I have the same ticking noise and plan on having it fixed in the next week or two. Sea foam may take care of it, but it may not do anything. On Atlanticbritish lifters are 220 and a cam for my 4.6 is around 170, you may only need lifters if the cam isn't damaged. But changing them out will require a full weekend of work if you do it yourself.
2003 Land Rover Discovery II |
#6 (permalink) | |
Ian Matthews
It comes down to whether a slightly noisy lifter is causing any damage. Or whether it is causing any performance issues. At 108,000 miles, it is worthwhile changing your cam if you are opening it up to replace lifters. So by leaving it you are unlikely to increase any repair costs. The difference in performance is most likely minimal. So by them saying that it is normal is more saying that it is not required to be fixed at this stage (depending on how much noise though). Putting cleaner through the motor will not fix your issues and runs the risk of damaging your motor. |
I have a really good shop in town that works on Benz, Bmw's, Volvos, Porsches, and Vw's ... Ive seen some Rovers there so Im gonna see how expensive it is to replace the Lifters and Cam ... I dont want my friends Disco to get messed up.
#8 (permalink) | |
As for the noise, it may be lifter/cam related or it can be the rocker arms. As for replacing the lifter and not the cam is ill advised, A cam lope/ if it has had some of it's hardened surface warn of will kill a new lifter quicker then you can do an oil change. So, start with the basics and work up. Mike |
| Thread Tools | |
| Display Modes | |
| Whistling noise while accelerating (rather loud) | jarnism | Discovery Series II | 3 | 02-24-2008 08:59 AM |
| Whistling noise while accelerating (rather loud) | jarnism | New Member Introductions | 1 | 02-13-2008 10:15 AM |
| HELP !! Strange Noise | stevenjamesdavies | Range Rover P38, Mk III and Range Rover Sport | 4 | 12-08-2005 03:14 AM |
| Squealing Noise on Startup -- Viscous Fan? | Oconee Disco | Discovery Series I | 3 | 09-14-2005 09:08 AM |
| Series 2 box noise. | Greg S | Series Land Rovers | 1 | 11-01-2004 12:15 PM |
