Locked in "Park" - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 25 (permalink) Old 07-09-2008, 06:16 AM Thread Starter
Quoted: 0 Post(s)
Locked in "Park"
I have a 2003 LR Discovery and encountered a problem this AM that I have not had before. I was at the Starbucks drive-thru this AM, placed the LR in park and then the "fun" started. The LR would not shift out of park.....it was locked in park with 6-8 cars stacked behind me. After about 10 minutes and a few restarts of the LR I was good to go.
Any thoughts on why the LR would lock in park?
bqr3 is offline
post #2 of 25 (permalink) Old 07-09-2008, 06:22 AM
Administrator
Quoted: 5 Post(s)
Next time it happens, which by the way is pretty common, check and see if your brake lights are working, if they aren't, it will be a bad brake switch.
I would advise you go buy one from Rover cause it won't be long before your's won't let you out of park again.
Disco Mike is offline
post #3 of 25 (permalink) Old 07-09-2008, 06:25 AM
Beach Bum
Quoted: 0 Post(s)
Break Switch?
Is this the classic break switch issue? I brought this up a few weeks ago and never heard anything. The break switch performs a number of functions
Trigers break lights
Toggles shift lock for getting the car out of park
Turn off shift lock function when car is in drive grears.
Not sure, I'd like to know if this is a common problem so I can go buy a spare switch if I need to. I just got a 25 cupon for a new part at LR. I need to use it.
brian4d is offline
post #4 of 25 (permalink) Old 07-09-2008, 06:39 AM
jmrivera's Avatar
Quoted: 0 Post(s)
Why don't you buy about 10 of them and we can all benefit form the discount....
'03 Discovery HSE7 w/ACE and SLS...
jmrivera is offline
post #5 of 25 (permalink) Old 07-09-2008, 06:55 AM
Beach Bum
Quoted: 0 Post(s)
brian4d is offline
post #6 of 25 (permalink) Old 07-09-2008, 08:00 AM Thread Starter
Quoted: 0 Post(s)
I checked the brake lights and they are working. Is it still the brake switch?
bqr3 is offline
post #7 of 25 (permalink) Old 07-09-2008, 08:23 AM
jmrivera's Avatar
Quoted: 0 Post(s)
When you apply the brake, do you hear a click near the brake pedal?
What about when you press the switch on the side of the gear selector???
jmrivera is offline
post #8 of 25 (permalink) Old 07-09-2008, 08:38 AM
Administrator
Quoted: 5 Post(s)
You can only test the brake lights when you can't shift, otherwise they will most likely be working.
post #9 of 25 (permalink) Old 07-09-2008, 10:15 AM
jmrivera's Avatar
Quoted: 0 Post(s)
Sorry, but I just realized this when I read the first thread agian...
I have a 2003 LR Discovery ... I was at the Starbucks drive-thru this AM...
Can this get anymore Soccer Mom or Yuppy ... No offense , especially since I have an '03 Disco., but this is funny...
jmrivera is offline
post #10 of 25 (permalink) Old 07-09-2008, 03:05 PM
Quoted: 0 Post(s)
Where does this brake switch go? (if it's a dumb question, sorry).
bugatti T35 is offline
post #11 of 25 (permalink) Old 07-09-2008, 04:52 PM Thread Starter
Quoted: 0 Post(s)
Somewhere behind the brake pedal. Need someone else to confirm and provide direction. I ordered a "switch brake light" from the link provided above. $18.95 + shipping.
bqr3 is offline
post #12 of 25 (permalink) Old 07-09-2008, 05:33 PM
jmrivera's Avatar
Quoted: 0 Post(s)
If you stick you head far underneath the driver side dash above the brake pedal, you'll see a 3-wire harness the is plugged into this plastic housing - that's the brake switch.. you may need a flashlight to see since it's pretty dark...
jmrivera is offline
post #13 of 25 (permalink) Old 07-10-2008, 05:40 AM
Beach Bum
Quoted: 0 Post(s)
Did you get a going out of Business Special?
brian4d is offline
post #14 of 25 (permalink) Old 07-14-2008, 05:00 PM Thread Starter
Quoted: 0 Post(s)
OK I received the switch brake light today. I can't see ithe 3 wire harness from underneath the dash. Can it be accessed from the front by opening up the panel where the fuses are located?
bqr3 is offline
post #15 of 25 (permalink) Old 07-14-2008, 06:43 PM
Beach Bum
Quoted: 0 Post(s)
Dont think.
Don't think so. Look at the switch, that button is depressed by the pedel itself, hope that helps.
brian4d is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Suggestion for lost key or being locked out tyl604 Discovery Series II 7 09-03-2008 12:35 PM
P38 Right Rear door locked shut Skip R Range Rover P38, Mk III and Range Rover Sport 0 10-14-2007 09:59 AM
viscous coupling locked up ryanc8514 Range Rover Classic 13 03-19-2007 04:43 AM
Locked keys in my truck today jnakoud Discovery Series II 15 05-19-2006 01:18 PM
Steering Wheel Locked, Key Won't Turn?? bluemax09 Discovery Series I 6 01-16-2006 12:39 PM
You may post new threads
You may post replies
