I am in the process of diagnosing a clunking noise coming from the front of my 99 D2. It happens upon decel around 20mph or normal driving in the speed range of 20-40mph. Heres my question:
Obviously, if I remove the front driveshaft, the vehicle will not move, so....is there a way to lock the diff. so only the rear is driving the vehicle? I think the noise is the driveshaft, but not sure. Also, it would be nice to be able to drive this thing in the event that I rebuild the shaft. |
4x4 Adventure Gear
Chris, early DIIs did not have the CDL linkage (your tansfer case is CDL enabled but it didn't come with the linkage). Does you shifter say Hi-N-Lo? You can fit a CDL kit. We carry the Ashcroft kit, you can also get a solenoid activated kit or one of the real cheap ones that require you to get out of the vehicle and engage the CDL.
Your noise is probably from the Transfer Case side and not the Driveshaft. The DIIs have a double cardon non-serviceable driveshaft. How many miles on your DII?
John C 1996 DI - 3" AG lift 1995 DI - Scorpion Racing Extreme Kit 1991 RR - parting out (few parts left) 1990 Kawasaki KL650B Tengai 1989 Kawasaki KLR650 |
#3 (permalink) | |||
![]() Quote:
4x4 Adventure Gear
Nope, you cannot lock the diff. Your knob should look like this
#6 (permalink) | |
4x4 Adventure Gear
4x4 Adventure Gear
He could but can you imagine how hard it would be.... the CDL was never engaged and it locks better when the vehicle is moving 5-8 mph... I can just see Chris trying to lock it while the truck is moving.
I really doubt that removing the Driveshaft will help, the clunk is probably coming from the TC (output bearing maybe). I recently removed the rear DS on my Disco and the clunking noise gets worse with only the fron DS installed. It's a typical LR problem.
#10 (permalink) |
4x4 Adventure Gear
Good point .... didn't think about that!
#12 (permalink) | |
#13 (permalink) | |
4x4 Adventure Gear
Yes, if you can get it to lock you will be able to drive it with one driveshaft.
#14 (permalink) | |
#15 (permalink) | |
