#16 (permalink) | |
Remember in the TD5 the boost comes from the vacuum pump, not the manifold as in the V8. This extra boost means that you get little feel in the brakes. Just to show it is as I say and not air in the system, with the engine stopped, press the pedal a couple of times. Once the surplus boost is used the pedal should be rock hard. If not you have air in the system. Richard Miller Australia |
#17 (permalink) |
Staring at the right rear and open the bleed valve allowing it to drip (through tubing into a container) until clear fluid comes thru (Takes quite a while), then close valve and go to the next wheel, then next, then next. Make sure you keep the resevoir full of clean fluid.
YMMV. This is a no effort job, and it helped mine to be tollerable. |
#21 (permalink) | |
Rocky - Northern Nevada 04 Discovery S "JeepHerder" Trans-Nevada-Trek Trailboss |
