Found out what the codes were and too lean bank 1 and 2. So I did some searching and it looks like the MAF is bad. My question is should I try cleaning it or should I just buy a new one. Some poeple also said it might be the O2 sensors, but I don't know how to check to see if they are bad.
thanks in advance Matt 1999 disco2 |
Not sure how to check an O2 sensor for failure.
It's got to have a way but I'm not sure there is a sensor tester. I'm not sure you can check an O2 sensor. |
#3 (permalink) | |
GOOD LUCK, RC PS OkieRover welcome to the DiscoClub ![]()
2006 Range Rover Sport HSE Rimini Red 2001 D2 CDL ![]() 1998 D1 ('Henry' Sold 05/05 Bought Back 01/06 Retired) 1988 RRC SWB ('Silver Bullet' Retired 05/98) |
You could try cleaning it with electrical cleaner (dry cleaning fluid). I've cleaned mine with no ill effect to the sensor.
Typically a bad MAF will also throw a transmission code too (705?). So lean banks might (big MIGHT) also be bad o2 sensors. I think you would need a diagnostic tool to check them out though, I don't think there is a multi-meter impedance check for them. If you DIY--start simple and cheap and progress to complex and expensive. |
Matt,
Who read your codes and said you were running lean? If the MAF is bad you will run rich. How many miles on your truck, are you still running factory plug wires? What octane gas and what is the truck doing wrong? By the way, cleaning will not bring a Bosh MAF back to life, just somewhat improve how the engine runs. Lucky for you your trucks MAF is only about $139 if it were needed. As for running lean, if you are at 100,000 miles, it is safe to say your O2's are waisted, of course the only way to test them is with a good scanner or test book. Get back to me, Mike |
Iam just shy of 100,000 miles and the truck is running just fine. I went autozone and had them run the test. I called the local dealer and asked them some questions and they said if it is running fine just leave it because it would cost me 90 to 150 for them just to look at it, but I can't just leave it. The only two codes it was throwing were 0171 and 1074 if I can rembere correctly without them in front of me. Mid grade oct and new plugs older wires not sure if they are factory or not.
P0171 & P0174 (lean banks) can be associated with a bad MAF. The MAF might be sending an incorrect signal to the computer, leaning out the mixture. Also clogged injectors may lean out the mixture too, so maybe a good dose of high quality injector cleaner may be in order. Another possibility is inadequate fuel pressure.
IMO--clean the MAF, clean the fuel injectors, and look for possible vacuum leaks first; then check the fuel pressure, then start looking at the high dollar items (MAF and O2 sensors). Good luck ![]() |
Ian Matthews
You can get rebuilt MAF sensors for about half the price of a new one. You can also buy code readers very cheaply. They will also reset error codes for you rather than going to a dealer to have it done.
Ian |
#9 (permalink) |
![]() Join Date: May 2005
too bad you can't reset those damn abs/tc/hdc lights with a code reader!!!
Moderator of the East Coast and Discovery 2 sections! 2001 Disco II SE w/CDL ~Equipe 4x4 Winch Bumper ~Custom steel rear bumper ~Equipe 4x4 steering skid and radiator skid ~RTE rocksliders ~QT services front and rear diff guards ~2" RTE lift ~265/75 r16 Federal Couragia MTs ~Superwinch X9 ~Safety Devices Roof Rack |
