MAF sensor and Vehicle speed sensor replacement - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 02-12-2013, 11:45 AM   #1 (permalink)
Default MAF sensor and Vehicle speed sensor replacement
i want to start by saying i havent posted much on the forum since ive joined, due to the fact that i have to keep working to keep the rover running lol. ive had the three amigos on for a couple weeks now, also the ses came on. i hooked up the scanner and it threw all O2 codes,and p1171 fuel air meter,a p1590 code for the vehicle speed sensor. my question is is the maf sensor causing the O2 codes[because i replaced all4 2 years ago] and if i change out the maf will it even help. i also plan on doing the plugs and wires at the same time. can anyone tell me the exact location of the vss,and will it cause the amigos to come on. any responses are greatly appreciated
Love-Hate Rover is offline   Reply With Quote
Old 02-12-2013, 12:25 PM   #2 (permalink)
Administrator
NO!!
Now, can you give us all the code numbers so we might better help you. Also what year and how many miles on it?
Need Parts?
paulgrant@mac.com or call 203-770-1699
willtillery@roverguy.com or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8, http://lucky8llc.com/
British Parts of Utah, http://www.bputah.com/
Old 02-12-2013, 02:10 PM   #3 (permalink)
sorry for not including that its 00 disco 2 with 138,000 miles and the codes are[theres alot of them] p0135,155,141,134,140,171,161,p1590,p1171. thanks in advance for any ideas/ or suggestions.
Old 02-12-2013, 06:47 PM   #4 (permalink)
Administrator
How is the engine running? With all those codes, before you do anything thing go to the parts store and have then do a free charging system test, needs to be between 13.6 and 14.4 volts.
If that is OK, still don't throw any parts at it, send me your number and I'll walk you thru what to check.
Need Parts?
Old 02-13-2013, 05:43 PM   #5 (permalink)
Mike, The motor seems to be running fine, every once in a while in the morning it has a rough idle until it gets up to temp. I figured that wasn t unusaul, seeing as how its below freezing here in centrl PA. I went and had the system charge test and it came back at 14.15 volts, occasional spike to 14.19, and a steady ripple around 3.6ish. Iwork 12 hr shifts, but you can reach me after 7:30pm at 717-968- 0988. Thanks again for the help,Jack
Old 02-13-2013, 05:51 PM   #6 (permalink)
Computer Nerd
jafir's Avatar
1590 isn't for a VSS. The D2 doesn't even really use a VSS the same way a D1 does.
____________________________
Jafir
2003 Discovery S, 132K
2004 Acura TL
1999 Discovery II, 110K (Project)
jafir is offline   Reply With Quote
Old 02-13-2013, 06:00 PM   #7 (permalink)
I guess i need to figure out what that code is for then. By any chance do you know? It came up on the scanner as p1590 manufacturer vechicle speed/idle speed control? Now im kinda confused!?
Old 02-13-2013, 07:09 PM   #8 (permalink)
Computer Nerd
jafir's Avatar
The land rover definition is rough road signal implausible. Basically it means that something is not right with the ABS system.
Jafir
2004 Acura TL
Old 02-13-2013, 07:25 PM   #9 (permalink)
How do you think i could go about narrowing that down? Do you think it could be something as simple as needing new pads and calibers triggering the fault and amigos to appear? Hopefully its not a tough fix because i dont have alot of knowledge when it comes to the LR abs system.
Old 02-13-2013, 08:00 PM   #10 (permalink)
Discovery II v8 2001
I had the same code - in my case it was squealing breaks causing three amigos. Changed the pads and the problem was solved. J
jiri_j is offline   Reply With Quote
Old 02-14-2013, 06:54 AM   #11 (permalink)
Administrator
Don't worry about the 1590 code, it is on because of your 3 amigos being on.
As for the other codes, if you want some help with this, send me your number and I'll call and walk you thru what to do and check.
Need Parts?
Old 02-14-2013, 10:16 AM   #12 (permalink)
Mike, I work 12 hour shifts, but you can reach me after 7:30pm at 717-968- 0988. Thanks again for the help, Jack.
Old 02-14-2013, 06:20 PM   #13 (permalink)
Well this morning iwent out to warm up the rover and there was snow and ice on the road. So i decided i would see if the abs was still functioning properly with the amigos on. I just checked the brakes at about 8 or 10 mphs and they totally locked the front wheels!! Long story short, my trucks anti lock isnt working. I was doimg some browsing online and came across a brake sensor/wheel speed sensor for a Disco 2 and it said one of the signs of a sensor failure is loss of anti lock,abs warning lamp(thats a surprise). Has anyone ever had this problem with this sensor? And if so how difficult are they to replace? Also how would i determine which wheel it is? This truck is making my head and wallet hurt!
Old 02-14-2013, 07:23 PM   #14 (permalink)
Im not sure which problem to address first, the abs system or the multiple codes.
Vehicle Speed Sensor crowe938 Discovery Series I 3 01-13-2012 04:07 PM
Speed sensor cleaning/replacement Glossy Discovery Series I 0 10-10-2010 08:32 PM
Vehicle Speed Sensor bobthebuilder Discovery Series I 6 10-23-2008 05:57 AM
vehicle speed sensor lwbblue Range Rover Classic 2 06-07-2007 04:55 PM
how do i replace vehicle speed sensor? aharbour Discovery Series I 8 02-14-2006 09:06 AM
SEO by vBSEO 3.3.2
