Old 08-07-2006, 08:14 AM   #1 (permalink)
02DISCOBLK's Avatar
Default Magnacore wires
I am wanting to know of the best place to get the magnacore wires? Also what kind of difference can you notice over the stock plugs and wires?
Thanks
02DISCOBLK is offline   Reply With Quote
Old 08-07-2006, 08:20 AM   #2 (permalink)
Go to Rover Connection, do yourself a favor and buy a set of Bosh Platium Plus 4's and you will get a lot of low end torque.
Mikee
Old 08-07-2006, 08:41 AM   #3 (permalink)
02DISCOBLK's Avatar
That sound great. Thanks alot.
Old 08-07-2006, 08:43 AM   #4 (permalink)
02DISCOBLK's Avatar
They are the 8mm wires correct?
Old 08-07-2006, 09:17 AM   #5 (permalink)
Yes
You know they are going to be a bugger to put on, do you have a small hand or are you going to remove the top half of the intake manifold?
Old 08-07-2006, 12:22 PM   #6 (permalink)
02DISCOBLK's Avatar
I do have a semi small hand. Which way is the easiest? Taking the instake off.
Old 08-07-2006, 01:47 PM   #7 (permalink)
When the engine is cool, take your habd and follow the wires back to the coil pcks, if you can work your way in there that will be great if not off comes the intaks.
Old 08-08-2006, 11:47 AM   #8 (permalink)
Otherwise known as STEVE
I got mine from 4x4AG. Haven't installed them yet- not looking forward to it since I have big hands AND secondary air injection. What a PITA.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 08-08-2006, 01:21 PM   #9 (permalink)
Steve,
You think you have large hands, you should see mine, not a chance in the world for mine to fit back there.
