Old 04-20-2008, 08:51 PM   #1 (permalink)
Talking Maintenance pays off at the pump
Well, I did some searching on here and asked a few questions before doing some routine maintenance. Thanks for the help guys! Looks like it may pay off for me. I was averaging alittle better then 17 mpg. The last tank of gas I checked before servicing the truck was actually 17.269 mpg. I checked my milage when I filled up today and got a surprise. Come out to be 18.135 mpg. That may not sound like much, but I am happy for every bit of improvement with the gas prices going up so much. I will have to keep a check on it to see if it stays that good.
The maintenance I did included Mobil 1 0W-40 synthetic oil, Mobil 1 oil filter, and Amsoil products in the transmission, transfer case, and differentials. I also put some Seafoam through it. I let it go in to fast and fouled a plug (P0307 cylinder 7 misfire). So, I also changed them using NGK Iridium IX plugs.
So far it is running smooth. I hope the mpg doesn't drop back off. Again, thanks to everyone for the help.
Neo1975 is offline   Reply With Quote
Old 04-21-2008, 12:20 PM   #2 (permalink)
Rycymru's Avatar
Just a little curious, was this all highway or a mix of intown and highway driving?
2003 Land Rover Discovery II
Rycymru is offline   Reply With Quote
Old 04-21-2008, 12:42 PM   #3 (permalink)
This is a mix, but mostly highway miles. Probably 60%-75% highway miles. Forgot to mention that I also changed the air filter. Used a Puralator air filter from Advanced Auto.
Old 04-23-2008, 08:29 PM   #4 (permalink)
dvldogduke's Avatar
Default Great Mileage
I am now a bigger fan than I was the Disco II. You have definitely hit the nail on the head with maintenance making a difference. I have been watching my Disco like a hawk, and actually had to replace my head gaskets. So all fluids in the engine were changed, tranny fluid for good measure as well. I just went through my first tank of gas. Filled up tonight, 20 miles to the gallon nearly on the dot!!! Better than the POS 4 door Blazer that I used to drive. Of course 20 gallons cost me a pretty penny at the pumps for 91 octane, but I am happy and that is what matters.
Duke
dvldogduke is offline   Reply With Quote
Old 04-24-2008, 08:51 AM   #5 (permalink)
nasa25's Avatar
changed my wires and plugs to OE a couple weeks back and my fuel efficiency has improved by around 10-15%. The shop that did my head gasket last year put NGK plugs in my v8 4.0, which I was told was all wrong by my LR mechanic. He put in new wires (I had the original 8 year old wires that came with the truck in there) and plugs (champion double platinum). Now once I deal with this annoying idler pulley that squeals like a banshee, I will be up to date.
nasa25 is offline   Reply With Quote
My SLS pump, let me show you it. V. Pics Grid_Lock Discovery Series II 2 03-30-2008 06:16 AM
hard start/fuel pump relay armydisco Discovery Series II 13 05-04-2007 03:39 PM
HELP!! Fuel Pump??? Truck still on trail. bluemax09 Discovery Series I 14 02-22-2006 04:40 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
No start, No power to fuel pump, ECU? Tiderover General Land Rover Discussion 2 09-17-2005 03:24 PM
