Old 10-06-2005, 07:47 PM   #1 (permalink)
drum655's Avatar
Default Making a CDL link
I want to make a linkage for my CDL....does anyone have any input into this idea. I know some of you have done this yourself....where is the lever located that locks the diffs?
2001 Disco II SE w/CDL
~Equipe 4x4 Winch Bumper
~Custom steel rear bumper
~Equipe 4x4 steering skid and radiator skid
~RTE rocksliders
~QT services front and rear diff guards
~2" RTE lift
~265/75 r16 Federal Couragia MTs
~Superwinch X9
~Safety Devices Roof Rack
drum655 is offline   Reply With Quote
Old 10-06-2005, 08:37 PM   #2 (permalink)
Roads?...Where we're going, we don't need roads...
keptin's Avatar
heres what I did, its pretty ghetto but it was nearly free and took me 3 hours to make. (hehe, I had no metal working tools, so I used a electric hand drill, wood drilling bits, a bolt cutter and a hammer) I also never ripped apart the console. I did everything with a nice flashlight, and a pocket mirror (OMG it was painful, but worth it). But hey, it was $$CHEAP$$
Here is the pic of the CDL switch, this is being taken with my hand reaching the camera under the body and taking a pic of the front top of the transfer case;
Basically followed this idea;
And made this;
and painted it with crappy paint, then W-40ed it before and put it on (which washed off the paint completely)
Here are different views (unfortunatly nobody in my town sells nylock nuts, becuase that is what I should be using, but remember, mine was the "Qualo-job");
I pull out to engage and push in to disengage....works like a charm.
Josh Shapiro
DII
Photos at www.kep1.com
Old 10-06-2005, 08:59 PM   #3 (permalink)
i like how you did that. I might think about something like that.
99 disco ii w/ cold climate and SLS.
plastic is offline   Reply With Quote
Old 10-06-2005, 09:10 PM   #4 (permalink)
keptin's Avatar
Plastic, its an essential. Supposedly it should be one of your first things (if you have it). Though so it bumper cutting and look at me *both hellas smashed, lower mesh grill crushed in, ready to fall off* "I love my bumper".
As for you drum, you have to make sure that your DII has the CDL. I was lucky to have a 01' feb., but if yours it a late model, maybe even jul-aug, it might not have the CDL, in which case you are screwed.
Josh Shapiro
DII
Old 10-06-2005, 09:31 PM   #5 (permalink)
rutlanddisco's Avatar
Not completly screwed. You can convert to a CDL. There are several manufacturers that make these now for about $300 dollars. They come with instructions. Dealership has never done one, so I am wary to convert myself. We don't have a place to try it ourselves.
I hope I am talking about the same thing you are. I am still a little new to "working" on my truck, But I am trying to learn so if I make stupid comments, pass it off to the girl in me and plz explain!
rutlanddisco is offline   Reply With Quote
Old 10-06-2005, 10:07 PM   #6 (permalink)
keptin's Avatar
Yep, there are kits and stuff that you can get for the 01-03 DII w/o the CDL, but I was saying screwed and refering to the CA$H that it will cost for the kits compared to the $5.00 for a custom linkage.
Josh Shapiro
DII
Old 10-06-2005, 10:21 PM   #7 (permalink)
ibjettin's Avatar
Great thread! thanks for posting your work! I have to go check and see if I could do it... I've been told it may be possible on the 2000?
2001 Audi allroad
1999 Volvo S80
1969, 1970, 1973, 1973tii BMW 2002's
2000 Discovery SOLD
CLick to see them
ibjettin is offline   Reply With Quote
Old 10-06-2005, 10:23 PM   #8 (permalink)
Rocky Mountain High
Funrover's Avatar
what does that do for you?
Old 10-06-2005, 10:30 PM   #9 (permalink)
keptin's Avatar
Hope this covers it funrover
EE, "Overview: The LT230SE transfer box used on the Series II Discovery is the same as the Series I. This transfer box has the latent potential to lock the front and rear driveshafts together for improved off-pavement traction (Center Differential Lock, referred to as "CDL"). If CDL is engaged when the engine is already running, then Electronic Traction Control is maintained. Otherwise, when CDL is engaged before engine start-up, tell-tale sensors feed back to the ECU, and ETC is deactivated. All that is required is to rotate the Selector Fork on the transfer box about 20 degrees clockwise to engage the lock the center differential."
basically just locks the two driveshafts so they run at the same speed, though you are still out of luck if you have a loss of traction on opposite (diagonal) tires. I wonder how good having a DII with 2 (front & rear) ARB's locked and the center locked....UBER traction maybe.
Josh Shapiro
DII
Old 10-06-2005, 10:35 PM   #10 (permalink)
Rocky Mountain High
Funrover's Avatar
that's what i thought but wasn't sure.....Thanx
Old 10-07-2005, 05:45 AM   #11 (permalink)
so the CDL linkage is on the top of the transfer case?
Old 10-07-2005, 07:22 AM   #12 (permalink)
keptin's Avatar
Yep, on the front-top of the case, facing up. Front being tward the front end of the vehicle.
Josh Shapiro
DII
Old 10-07-2005, 08:04 AM   #13 (permalink)
imag's Avatar
hey keptin,
ypur website (in your signature) is super cool, specially the video and music. Wow.
2001 Discovery SE7
imag is offline   Reply With Quote
Old 10-07-2005, 09:20 AM   #14 (permalink)
Default keptin
I am confused... I have an 00 disco, does that have a CDL? Can I do what you did or not?
Old 10-07-2005, 10:36 AM   #15 (permalink)
Wheeler
SCSL's Avatar
And '00 DII should have the CDL "nipple" on the t-case.
(as well as roughly 1st 1/3-1/2 of '01 production)
