Old 07-05-2005, 02:09 PM   #1 (permalink)
Chris Hyde's Avatar
Default Manifold -->Intermediate Pipe Gasket Replacement
I am getting a small exhaust leak at the gasket where the exhaust manifold meets the intermediate pipe on the passengers side. I have known this to be a common problem in the past. On my last Disco II, due to heavy rust at the joint, I ended up breaking off both studs and had to remove the manifold, etc to get it repaired. It was a royal PITA.
Is there a secret to getting to this gasket without breaking the (2) manifold studs that connect to the interm. pipe?
Signs Over Georgia
770-704-0377
www.SignsOverGeorgia.com
-Discovery I & II Hood Blackout Kits
-Car Graphics
-Custom Signs/Decals/Stickers
-Shirt Printing
Chris Hyde is offline   Reply With Quote
Old 07-06-2005, 08:32 AM   #2 (permalink)
Chris Hyde's Avatar
Am I the only one that has had 2 Disco II's with this problem?
Signs Over Georgia
770-704-0377
-Car Graphics
-Shirt Printing
Old 07-06-2005, 03:39 PM   #3 (permalink)
The only secret I have is to put anti-sieze compound on the threads BEFORE you install the hardware; but that doesn't help your problem. Maybe lots and lots of break-free product and a wire brush before attempting to remove the nuts. Then slowly loosen, adding more break-free as required.
O.B. is offline   Reply With Quote
Old 07-07-2005, 12:40 PM   #4 (permalink)
Chris Hyde's Avatar
bump
Signs Over Georgia
770-704-0377
-Car Graphics
-Shirt Printing
Old 07-07-2005, 01:04 PM   #5 (permalink)
4x4 Adventure Gear
John C's Avatar
Use PB Blaster (not WD40) and let it sit for a while. Clean the end of the studs off as best you can (I know, it's hard to do but try to get a small wire brush and clean off the end of the studs). Turn the nut slowly and pray!
Good luck and let us know how it goes.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 07-07-2005, 01:17 PM   #6 (permalink)
Originally Posted by Chris Hyde
bump
What does that mean?
Old 07-07-2005, 06:27 PM   #7 (permalink)
you bumb a thread to move it up in the forum, when no one responds to your question, or if you think what someone else has written is important.
99 disco ii w/ cold climate and SLS.
plastic is offline   Reply With Quote
Old 07-07-2005, 06:43 PM   #8 (permalink)
I get it--many thanks!
