Old 10-05-2005, 09:07 PM   #1 (permalink)
imag's Avatar
Default Metal shavings on oil drain plug
I changed the front and back differential's oil last weekend, it seems as if this hadn't been done before (72K 2001 model). There was an impressive array of metal shavings on the magnetic plug.
Anybody else seen these before on Disco's ?
I guess that without a service history when buying a used Disco (or any other vehicle), it's good to go and change all oils asap.
2001 Discovery SE7
imag is offline   Reply With Quote
Old 10-05-2005, 09:23 PM   #2 (permalink)
Rocky Mountain High
Funrover's Avatar
Looks like it came out of a cave......I would flush that out with oil and drain + fill again
Old 10-05-2005, 09:29 PM   #3 (permalink)
Proud to be an Infidel
FlyWheel's Avatar
IMAG,
I agree with FUNROVER. Dont panic but another oil change is in order.
I too have an 01 unit and had some shavings. Hopefully it is from the initial break in. Check the thread with the synthetic options and see if you can use AMSOIL.
2001 Disco SE7
.......eventually they will run out of suicide bombers.....
FlyWheel is offline   Reply With Quote
Old 10-10-2005, 12:40 PM   #4 (permalink)
You've got a female plus in there. Replace it with a male one.
Big Kat is offline   Reply With Quote
