Misfire or Vibration? Help - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 01-01-2013, 09:27 PM   #1 (permalink)
Default Misfire or Vibration? Help
Hi there.
I have a 2000 disco 2.
Over the last few months i have had lots of stuff done to it to keep it running.
The last thing i had done a few weeks ago was the water pump, cam chain cover gaskets, head gaskets and plugs and wires changed.
The last few days the thing has been running rough around 1800-2500 revs and i'm not sure if it's a misfire or a vibration.
I do have an abs amigo but thats not showing any codes? Does the abs amigo read all codes or just codes relating to the 3 amigos?
I may remove the front prop to see if the vibration is still there but i need to use the rover to get to work. How long can you drive with the front shaft disconnected? The rover has done 126000km.
shnez is offline   Reply With Quote
Old 01-02-2013, 06:23 AM   #2 (permalink)
Administrator
It will only read ABS codes. What have you checked so far, whos plug wires did you install?
Need Parts?
paulgrant@mac.com or call 203-770-1699
willtillery@roverguy.com or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8, http://lucky8llc.com/
British Parts of Utah, http://www.bputah.com/
Old 01-02-2013, 08:48 AM   #3 (permalink)
I took it to an independent land rover specialist here in Calgary. So i'm pretty sure they would have used the correct plugs and leads.
If i buy a code scanner today and no codes show am i safe to assume theres no misfire?
Should any dash lights appear if theres a misfire?
Old 01-02-2013, 01:16 PM   #4 (permalink)
So i'm going to pull the front prop as a precaution but just plugged in a code scanner and got
P1884
P0102
P0112
I have reset but don't want to drive the thing to see if the miss or vibration is still there as i'm scared of the worst case scenario.
Old 01-02-2013, 03:54 PM   #5 (permalink)
Prop shaft it was!
No misfire and no vibration. Also no codes!
So i couldn't get the bolts out of the transfer case side?
Are they ok to leave loose and use until i fit the new prop as i don't have a big socket to get that front plate off.
Old 01-03-2013, 03:14 AM   #6 (permalink)
Administrator
Not sure if they will remain there without the drive shaft.
Who's drive shaft are you getting?
You know, you can engage the CDL and drive on the rear shaft only in the mean time.
Need Parts?
misfire help MR.T Discovery Series II 7 05-11-2011 07:36 PM
Vibration @ 75 antelope44 Discovery Series II 3 09-22-2010 04:21 PM
Vibration Jack-the-Lad Range Rover Classic 4 11-26-2009 07:41 PM
Vibration etrnly Discovery Series I 7 12-30-2005 06:29 PM
misfire log burner Series Land Rovers 0 12-04-2005 03:15 AM
SEO by vBSEO 3.3.2
