Old 04-15-2008, 06:28 AM   #1 (permalink)
coldfrez's Avatar
Default Moisture
Hello Gents.
Lately my wife has been complaining of a musty oder in the Disco when she gets in it in the morning. So I looked into it and found the oder eminating from the right side foot well. I have heard that Discos tend to leak water in that area, and therefore i may be experiencing this in my Disco. this could also be the problem im still experiencing with the spedo. My question is...where exactly is the leak generally found, and could i seal the area so it does not leak.
As always Thank you in advance....
Feb 2001 disco II
"ANOTHER DAY IN PARADISE"
coldfrez is offline   Reply With Quote
Old 04-15-2008, 07:24 AM   #2 (permalink)
Sounds like your 2 drain tubes for your a/c are plugged up. If so, crawl under your truck with a flash light, look on the bottom side of the floor on each side of the transmisson for 2 small black rubber grain nipples and just give them a couple of good squeezes and watch the water come out.
Then, you might want to work on cleaning and drying out your carpet or it will get worse.
Spark Plug Wires-Testing RageRover Range Rover Classic 16 05-18-2006 06:36 AM
Water Moisture Interior Windshield PDX Disco II Discovery Series II 2 03-10-2006 02:56 PM
moisture in front lights DiscoSE03 Discovery Series II 1 11-20-2005 04:49 PM
