Old 08-26-2008, 07:21 PM   #1 (permalink)
Panerai_Pete's Avatar
Location: Normally, just outside of Detroit, now way outside...ie Shelby Township....Help?
Default Moisture on the Lamps...
I have noticed that some of my lights, break & head lights etc. Have moisture inside the shell of the lamp? I understand why the driver side has the problem because there is a crack in the seal of the shell, but lately I noticed that the back lights are starting to show moisture on their internal side of their shell.
So my questions is, I have a farily good idea what is causing the problem, but my question for you kind people is, where would you recm'nd that I get some new "seals" for these lights? (As I assume that this is the reason, the leaking seals that is?)
What I am looking for is a place to buy the seals, or maybe a better set of seals?
Thanks
Panerai_Pete is offline   Reply With Quote
Old 08-26-2008, 09:59 PM   #2 (permalink)
2002 Discovery II SE
I was told by a rover mechanic that you have to replace the whole headlight, because there is no kind of seal kit. I guess once its apart, its apart.
The rear lower tailights have a seal (I think a little foam thing) and I imagine the rear upper taillights must have a seal, since you can take the lense off.
Maybe try rovers north?
2002 Discovery Series II SE. 2" OME Heavy Duty. 265/65R18 BF Goodrich All-Terrain T/A's.
I told my wife if the Land Rover goes, so do I. That shut her up.
Alak is offline   Reply With Quote
Old 08-26-2008, 11:09 PM   #3 (permalink)
I haven't really looked at it, but what kind of seal is it?
I don't remember, but can you see it from the outside? If not I'd maybe try a different style seal if it's internal. Maybe a foam self-adhering type.
I really can't picture it off hand.
tablets is offline   Reply With Quote
F/S Hella Hydrolux Lamps 01001010 Land Rover Parts and Accessories 17 10-11-2008 10:29 AM
D2 Brush Guard with Driving Lamps - $ 2Discos95-00 Land Rover Parts and Accessories 0 06-19-2008 02:07 PM
Cibie I95 fog lamps and extra lenses roverpwr Land Rover Parts and Accessories 0 04-08-2007 10:23 PM
2006 LR3 - Installing Fog Lamps a12lr3 Discovery 3 / LR3 0 11-12-2006 08:09 PM
Converting to 03'-04' DII tail lamps ibjettin Accessories 0 09-21-2005 01:48 AM
