Old 11-21-2006, 09:47 AM   #1 (permalink)
greekdisco's Avatar
Default Mud water in Headlights
so basically i went fourwheeling yesterday and got water in both headlights what should i do ? the waters sitting at the bottom of the high beams.
by the way i got stuck due to having bald goodyear HP's (getting Nittos In a couple weeks )
greekdisco is offline   Reply With Quote
Old 11-21-2006, 09:50 AM   #2 (permalink)
01001010's Avatar
Gallery: 15
Do you have an 03/04 Disco? I dont think it would be any different than just unclipping the whole bezel and removing it...unplug the bulb and remove the rubber grommet behind and just let the water drain
JC...
Old 11-21-2006, 09:51 AM   #3 (permalink)
rmuller's Avatar
pop the headlights out, pull the light bulbs, and drain them.. maybe run some more water through there to get the mud out.. do NOT let it sit for too long as it starts to get way more difficult to get out.
Old 11-21-2006, 10:10 AM   #4 (permalink)
XXXX2, I agree and also check the drain tubes, making sure they are open so water will drain out when needed.
Old 11-21-2006, 12:21 PM   #5 (permalink)
For what it's worth, I drilled a tiny hole in the bottom of my old '01 lights that did the trick- never had an issue again.
Jharv is offline   Reply With Quote
Old 11-21-2006, 01:29 PM   #6 (permalink)
greekdisco's Avatar
i think both my head lamps are broken because one of the screws on both lights wont come out
Old 11-21-2006, 02:28 PM   #7 (permalink)
What screws, are you talking about the headlight adjuster screws, they are not supposed to unscrew, just a partial rotation and they slip out of the metal housing.
Old 11-21-2006, 03:00 PM   #8 (permalink)
01001010's Avatar
Gallery: 15
Just thought of this as well...if you managed to get water passed the rubber gromet and into the bezel, you were in deep and you were in longer than just a moment...so check that all of your electricals work and if you're going to be visiting water often, start spreadin some dielectric grease on electrical connections under the hood (including plug wires) and you might want to start setting some funds aside for a snorkel.
JC...
Old 11-21-2006, 03:46 PM   #9 (permalink)
greekdisco's Avatar
water wasnt that deep at all butill check the lights again
Old 11-21-2006, 05:17 PM   #10 (permalink)
Ian Matthews
p76rangie's Avatar
Just get it out as soon as possible. The dirty water will take the reflector surface in the light off very quickly. It may already be too late and you will be up for new lights.
Old 11-22-2006, 09:37 AM   #11 (permalink)
greekdisco's Avatar
well that sucks will warranty coverthese since it is an offroading suv
Old 11-22-2006, 02:16 PM   #12 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
The headlights just pop out, nothing to unscrew.
Badger1 is online now   Reply With Quote
Old 11-22-2006, 02:40 PM   #13 (permalink)
It is a 60/40 chance they won't cover the head lights, one maybe but when both happen they will be a little more cautious in replacing them.
