Old 06-08-2008, 08:33 PM   #1 (permalink)
akabaa's Avatar
Default multiple coolant leak issues
2002 Disco II, 99K:
(A) For some time I had the coolant leak at the throttle barrel with a little coolant dripping on the valve cover. Was going to replace the gasket on a day I didn't feel my thumbs were too big.
(B) Now I have a coolant leak on the same engine side dripping down the bell housing area - about 1/8 to 1/4 cup after I turn the engine off and of course while the engine is running. I can't for the life of me find where the leak is.
(C) In the process of searching for the (bell housing) leak I discovered that the throttle barrel gasket is NOT leaking any more.
I have read all the posts relating to coolant leaks - but I still have a couple of questions.
Could the stopping of the throttle barrel gasket leak be related to the drip down the bell housing? Will a pressure check with dye be able to find the bell housing leak? The leak seems to be between the engine and fire wall some where. Will the test show a intake or head gasket? Could the test damage anything if not done correctly? Thanks
akabaa is offline   Reply With Quote
Old 06-09-2008, 06:02 AM   #2 (permalink)
Go have your coolant system pressure tested.
Old 06-09-2008, 06:46 AM   #3 (permalink)
akabaa's Avatar
Mike - what kind of shop will do the pressure testing?
Old 06-09-2008, 09:27 AM   #4 (permalink)
Just call around, radiator shops do them as will most shops that work on Rovers.
Old 06-09-2008, 10:22 AM   #5 (permalink)
Elemental's Avatar
Agree with testing/not guessing!
That said, Bell housing coolant leaks are alomsot always intake gaskets.
When I was done with her, her bed needed Shamwow sheets!
Old 06-09-2008, 08:51 PM   #6 (permalink)
akabaa's Avatar
Default pressure test leaker
Flat beded the ol gal into town to have a pressure test. Not conclusive except the it did not come from the head gasket seam, but higher yet. And she did leak with the pressure applied. SOOOO she is to have a intake gasket replacement, a new set of magnacore ignition wires while were at it and plugs all round. Thanks for all your help.
Greg
Old 06-09-2008, 09:44 PM   #7 (permalink)
Rebuilding Rover
ArmyRover's Avatar
Ding we have a winner intake gasket is my thought as well.
http://www.wheelinrovers.com/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Cylinder#6 Misfire & Coolant Leak tskim2024 Discovery Series II 3 02-09-2008 10:07 AM
lets play guess the source of the coolant leak gragravar Range Rover Classic 7 10-31-2007 08:31 AM
Strange coolant leak..!! DiscoDoggII Discovery Series II 9 10-29-2007 04:46 PM
Small Coolant leak...Blow Head Gasket? maverick544 Discovery Series II 9 09-22-2007 09:27 AM
Yet Another Coolant Leak drprofessional Range Rover Classic 4 03-29-2007 02:46 PM
