I bought the Disco II about six months ago and have had no trouble with it. It is siting on 145,000 miles right now. Do you guys have any ideas about what I need to do to maintain this truck? Some checkups that need to be done, etc. I had it looked at by my mechanic here in town that works on LR's and BMW. He said it looked to be in great shape, but he had to replace some clamps r something. Anyway, I would appreciate some help.
#4 (permalink) | |
1999 DII 2001 DII (w/ACE) |
I did miss that one, I think I had a bad night.
Mileage would be good though. Here is my list of stuff to do to make a new, used vehicle ready to go. This is the parts list for a 60,000 mile service or a high mileage used truck, the way I do it. 1 Oil filter, K&N 3001 1 Air filter 6 Qts of engine oil 12 Qts of ATF 7 Qts of 80/90W gear oil 2 Qts of Brake fluid 2 Qts of synthetic Power steering fluid 2 Gallons of OAT, orange coolant 1 Bottle of Lucas Power Steering additive 1 Bottle of Lucas Transmission additive 1 Can of Spray Carb. Spray 1 Can Of Brake cleaner 8 Spark Plugs, I use Bosch Platium Plus 4's 1 Set of Magnacor 8mm plug wires 1 Serpentine belt if not yet replaced 2 Bottles of SeaFoam 60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased Bleed the brakes Flush and change the power steering fluid adding one bottle of additive Service the tranny adding one bottle of additive Flush the coolant system Do an engine flush before changing the oil Do an induction cleaning Clean the throttle body Add fuel additive to full gas tank Change both of the diffs fluid Change the t/case oil Replace the plugs and wires Replace the air filter Lube all the drive shaft grease fitting including the 2 slip shafts Do full inspection of brakes, hoses, bushings etc. Hopefully I didn't leave anything out. Mike |
'00 DII Member
BamaFan,
Who is your local mechanic in T-Town? If you have a chance you should take it to Christian Brothers in Hoover. They've done some work on quite a lot of "soccer mom" rovers in the greater Birmingham area, and the guy that owns the shop is top notch. I'm sure they would be more than happy to take a look over it and make suggestions for you. They pressure tested mine for free to help me find a coolant leak (stupid thermostat) and have changed gasket here and there. Anyhow, you could grab the list Mike made for you (I think there is a similar one in your handbook), run by there and they could quote you. I've found them to be BY FAR the best price in town, and they know what they're doing. How are your breaks? Hoses? Any drips?
'00 DII '07 Toyota Taco War Eagle! |
Well my mechanic is actually in Tuscumbia, AL. That is where I have family and they knew he was there. Name is BJ Kennamore. Where is the Christian Brothers shop? I have replaced the brake pads and rotors, and I haven't noticed any drips.
| Thread Tools | |
| Display Modes | |
| Famous Owners of Land Rover vehicles | Bleed Green RRC | The Lounge | 37 | 08-28-2006 12:40 PM |
| Land Rover Frequently Asked Dumb Questions (very long...but funny) | JungleRR | General Land Rover Discussion | 0 | 05-26-2006 09:37 AM |
| Land Rover: Truly 'Extraordinary' | Serg | General Land Rover Discussion | 0 | 01-30-2006 11:37 PM |
| 1999 4.6 needs some work; fix or sell? | Spring | Range Rover P38, Mk III and Range Rover Sport | 17 | 01-29-2006 01:18 PM |
| Range Rover Sport Seems to have it all | Serg | General Land Rover Discussion | 1 | 12-05-2005 12:54 AM |
