While going up hill it will downshift, have a werid bump, then go into gear. It dosent do it all the time but i can notice it. I duno if yall can tell what im asking its kinda hard to expalain
99' DII Niagra Gray SOLD ![]() 05' Subaru WRX STi Krystal Ghey Metallik ![]() Revived 91' Isuzu Trooper Brownish-chipped-dented-rusty-white...275k and still kickin
duno im the 2nd owner, no records
i havent checked yet, ill have a look tomorrow
I agree to an extent, change the fluid and filter, do not flush it, too many miles to flush it without the possibility of trashing it. Also add a bottle of Lucas transmission additive. 10,000 miles from know change it again with out the filter , still add the Lucas.
You also might have yor u-joints inspected and lubed, including inspecting the double cardon and replacing those u-joints if they don't have grease fittings. Pull the plugs on both drive shafts slip section and insert grease fitting and lube it well. That should take care of your problem unless the tranny has been damaged internally, have you had any warning lights? Mike |
#9 (permalink) |
no warning lights like check engine or anything. But i hit a big bump in the road(the truck lifted off the ground) and about all the dash lights came up, but i turned it off and they were gone when i started it back up
#11 (permalink) |
thanks man, i guess ill have the rear drive shaft refirb'd when there working on the trany
#12 (permalink) |
![]() Join Date: May 2005
i would worry more about the front drive shaft witrh the double cardon before i would worry about the rear!
Moderator of the East Coast and Discovery 2 sections! 2001 Disco II SE w/CDL ~Equipe 4x4 Winch Bumper ~Custom steel rear bumper ~Equipe 4x4 steering skid and radiator skid ~RTE rocksliders ~QT services front and rear diff guards ~2" RTE lift ~265/75 r16 Federal Couragia MTs ~Superwinch X9 ~Safety Devices Roof Rack |
#13 (permalink) | |
Mike |
#14 (permalink) |
the front is out right now....
