Old 08-29-2006, 08:08 PM   #1 (permalink)
d2sti's Avatar
Default is my tranny trying to go?
While going up hill it will downshift, have a werid bump, then go into gear. It dosent do it all the time but i can notice it. I duno if yall can tell what im asking its kinda hard to expalain
99' DII Niagra Gray SOLD
05' Subaru WRX STi Krystal Ghey Metallik
Revived 91' Isuzu Trooper Brownish-chipped-dented-rusty-white...275k and still kickin
d2sti is offline   Reply With Quote
Old 08-29-2006, 09:16 PM   #2 (permalink)
Rocky Mountain High
Funrover's Avatar
Check fluid level...also..when was your last service(flush/filter)?
Old 08-29-2006, 09:29 PM   #3 (permalink)
d2sti's Avatar
duno im the 2nd owner, no records
Old 08-29-2006, 09:38 PM   #4 (permalink)
Rocky Mountain High
Funrover's Avatar
How many miles?
Old 08-29-2006, 09:50 PM   #5 (permalink)
d2sti's Avatar
109k
Old 08-29-2006, 09:57 PM   #6 (permalink)
Rocky Mountain High
Funrover's Avatar
I'd say do a tranny flush..change the filter...... is the fluid dark or have a burnt smell?
Old 08-29-2006, 10:09 PM   #7 (permalink)
d2sti's Avatar
i havent checked yet, ill have a look tomorrow
Old 08-30-2006, 07:19 AM   #8 (permalink)
I agree to an extent, change the fluid and filter, do not flush it, too many miles to flush it without the possibility of trashing it. Also add a bottle of Lucas transmission additive. 10,000 miles from know change it again with out the filter , still add the Lucas.
You also might have yor u-joints inspected and lubed, including inspecting the double cardon and replacing those u-joints if they don't have grease fittings. Pull the plugs on both drive shafts slip section and insert grease fitting and lube it well.
That should take care of your problem unless the tranny has been damaged internally, have you had any warning lights?
Old 08-30-2006, 01:31 PM   #9 (permalink)
d2sti's Avatar
no warning lights like check engine or anything. But i hit a big bump in the road(the truck lifted off the ground) and about all the dash lights came up, but i turned it off and they were gone when i started it back up
Old 08-30-2006, 01:45 PM   #10 (permalink)
So, change the fluid and lube her up, pretty inexpensive to do and should cure your problems.
Old 08-30-2006, 03:05 PM   #11 (permalink)
d2sti's Avatar
thanks man, i guess ill have the rear drive shaft refirb'd when there working on the trany
Old 08-31-2006, 09:03 AM   #12 (permalink)
drum655's Avatar
i would worry more about the front drive shaft witrh the double cardon before i would worry about the rear!
2001 Disco II SE w/CDL
~Equipe 4x4 Winch Bumper
~Custom steel rear bumper
~Equipe 4x4 steering skid and radiator skid
~RTE rocksliders
~QT services front and rear diff guards
~2" RTE lift
~265/75 r16 Federal Couragia MTs
~Superwinch X9
~Safety Devices Roof Rack
drum655 is offline   Reply With Quote
Old 08-31-2006, 09:09 AM   #13 (permalink)
I agree, first, what is wrong with the rear shaft and have you had the front double cardon inspected on the front shaft, they are guarenteed to fail if they have no grease fittings. Also make sure you have both slip shafts on your drive shafts lubed, they will bind up and cause lots of problems.
Old 08-31-2006, 01:20 PM   #14 (permalink)
d2sti's Avatar
the front is out right now....
