Disco newbie
Hello all.
First thing first. I've got a lot of questions, so "Thank you" in advance for reading, and any help you may have for this Disco newbie. Ok...long story short. I've been a long time Jeep owner. Just bought my first Disco. What are the "daily" maintainence issues I should not ignore? (i.e.oil type, new injectors...that sort of thing) There will be more to come. I am very excited and look forward to all of the expert advice, and different opinions I see you all posting. Thank you again |
2004 Discovery II driver
I'm not the best one to tell you (i'm still under a factory warranty), but I'm running Mobil 1 oil.
pointers- when changing spark plug wires go with magnacor and don't run air filters other than factory paper filters, K&N style filters can mess up MAF sensors (due to the oils)
![]() 2004 Discovery II SE7 - My Ride 2006 LR3 SE - Dad's Ride |
This is Disco Mike's to do list when you purchase a used Discovery II:
This is the parts list for a 60,000 mile service or a high mileage used truck, the way I do it. 1 Oil filter, K&N 3001 or Mobil 1 1 Air filter 6 Qts of engine oil 12 Qts of ATF 7 Qts of 80/90W synthetic gear oil 1 Qt of synthetic Brake fluid 2 Qts of synthetic Power steering fluid 2 Gallons of OAT, orange coolant 1 Bottle of Lucas Power Steering additive 1 Bottle of Lucas Transmission additive 1 Can of Spray Carb. Spray 1 Can Of Brake cleaner 8 Spark Plugs, I use Bosch Platium Plus 4's 1 Set of Magnacor 8mm plug wires 1 Serpentine belt 2 Bottles of SeaFoam gas additive 1 T/Stat 60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased Bleed the brakes Flush and change the power steering fluid adding one bottle of additive Service the tranny adding one bottle of additive Change the coolant and t/stat Do an engine flush before changing the oil Do an induction cleaning Clean the throttle body Add fuel additive to full gas tank Change both of the diffs fluid Change the t/case oil Replace the plugs and wires Replace the air filter Lube all the drive shaft grease fitting including the 2 slip shafts Do full inspection of brakes, hoses, bushings etc. What year is your Disco and how many miles?
1999 DII 2001 DII (w/ACE) |
Oil type discussion can be found here
OiL -- I personally run Rotella 15w 40 in the summer months and rotella 5w 40 in the winter. Injectors don't seem to be an item that fails that often in the DII (at least not that I've read). Periodically running a can of 44K through there is not a bad idea though. If it hasn't been done, you'll want to upgrade your front driveshaft with greasable u-joints. Do a search on here and you'll find out why. |
