Old 09-05-2006, 10:36 AM   #1 (permalink)
Polish and proud of it.
TsiArt's Avatar
Default New Parts needed
I know someone mentioned that we can buy parts cheaper then dealer . But I can't remember the name of the web site or the place .
What I need is :
-Timing chain
-head gaskets
-intake manifold gasket
-colant hose ( the water pump / heater core / something / thermostat ) It's that fonky looking one.
-driver side radiato braket ( bolted to the chassy to keep the radiator from flapping around ) ( missing cause someone did not istalled it back in ) .
-rear xmember bolts ( 2 out of 8 snaped and other 2 got rounded off when the socket broke, so at least 4 of them I need )
-Head bolts ( I will see how much it will cost me to get ARP head studs )
-exhoust down pipe gaskets .
Now I don't even want to think about the total bill . BTW I'm doing all the labor my self , so it will be a LOT cheeper then the dealer , but still I did not wnat to do it .
This saturday i'll be working on a Lancer MR , installing some electronic goodies and engine stuff . we will see how fast it will be on saturday night . BTW that install money will help me with the bill for parts .
I'm a Proud owner of a vehicle that has a turning Radius of 747
Check out our Frappr!
Myspace ? It dose not mather who votes, only matters who counts the votes _ Krushchew
TsiArt is offline   Reply With Quote
Old 09-05-2006, 10:44 AM   #2 (permalink)
3 for starters,
Atlantic British
DAP
Rover Connection
Good luck with the project, sounds like fun. Whaqat is the mileage on your truck? Have you thought about about O2 sensors, Atlantic British has them on sale. Don't forget a new derpentine belt.
Also, do a gian't engine flush prior to tear the engine down, Replace all six qts of engine oil with ATF and let it idel for 15 oe 20 minutes, this will give you a much cleaner engine to work on.
Old 09-05-2006, 10:59 AM   #3 (permalink)
TsiArt's Avatar
Thanks .
O2 sencors were replaced when the truck had a problem with the MAS air metter ( ODBII was saing that it was the O2 , when actually was MAS air , so someone replaced them b4 i got the truck , cause they are new ) .
The engine is already out and the engine is more durty on the outside then inside anyway . So when the ligth went out in the garage you could not see me untill i smiled .
Yes I have a new belt in the trunk , but I think i will buy a Land Rover one instead of that ( goodYear auto zone crap ) . I keep belts in the trunk just incase i snap one for what ever reason on the road ( my dad told me to keep one spare ) .
Thank you again .
