New Vacuum sound at start up.... - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 5 (permalink) Old 01-20-2011, 12:31 PM Thread Starter
James Hewitt
jhewitt1111's Avatar
Quoted: 0 Post(s)
Garage
I am used to the sounds when I start my disco. But this morning and after work today when I started it there was an unrecognizable noise. It sounded like a high pitch vacuum cleaner wine. It last as long as the normal sounds and after about 2 min cuts off. No change in anything else with the car. Where should I start looking?
2000 Disco II w/134,000 miles, TW shaft, 265/75/16 GY wranglers, Rage basket, Factroy Brush Guard ($80 on craigslist), Kingsborne red 8mm, and Akebono pads (all the way around)...
"I understand the jeep thing, thats why I bought a Rover"
"You can't change everything you face, but you must face everything in order to change"...
jhewitt1111 is offline
post #2 of 5 (permalink) Old 01-20-2011, 01:49 PM Thread Starter
James Hewitt
Quoted: 0 Post(s)
Garage
SO when I got home I opened the hood and went up front. I throttled up a bit to see if I could find the sound. It is a high pitched wine. It really sounds like it is coming from the throttle body itself. I am going to do an induction cleaning as well as clean the inside of the throttle body. Any other thoughts?
post #3 of 5 (permalink) Old 01-20-2011, 03:08 PM
Quoted: 0 Post(s)
does the truck have secondary air, the chrome valves would be on both sides of the engine, when the engine is cold the secondary air will make a loud like a vacuum or hair drier sound, this normal, does the truck have high miles & what year is it.
98D1 is offline
post #4 of 5 (permalink) Old 01-20-2011, 06:32 PM Thread Starter
James Hewitt
Quoted: 0 Post(s)
Garage
2000 disco II with SAI and it has 134,000 miles. I did find a vacuum hose undone. But the sound continued after I fixed it. I was planning on opening the hood tomorrow when I start it to leave in the am.
post #5 of 5 (permalink) Old 01-20-2011, 08:41 PM
hafaday's Avatar
Quoted: 0 Post(s)
check the opposite side of the intake (from the throttle body), there are 2 hoses that go into the intake. directly under those hoses there is another connection capped off... that blank rubber cap will rot/crack and fall off. this might be the source of the "whistle" sound.
01 d2
Bill H.
The Rave on pdf's.
hafaday is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
97landrover disco will not start after being driven. but will start after along wait. fabson59 Discovery Series I 4 12-29-2010 07:32 AM
Vacuum. Is it On. vonbrandt Discovery Series I 3 10-26-2009 12:26 PM
Hard to start/No start...VERY COLD OUTSIDE (8 deg. F) BullDogSix Range Rover Classic 23 01-16-2009 07:28 AM
95 Disco deep puddle, wouldn't start, now really won't start littleg Discovery Series I 3 10-07-2008 08:08 PM
90. servo vacuum Wagman Defender 0 03-14-2005 11:01 PM
You may post new threads
You may post replies
