newbie checking in - Land Rover Forums : Land Rover and Range Rover Forum
 2Likes
  • 1 Post By CT090
  • 1 Post By discomania04
post #1 of 7 (permalink) Old 04-20-2017, 09:19 AM Thread Starter
Quoted: 4 Post(s)
newbie checking in
oh, hi there
Proud, or not quite sure if I am, of 99 disco 2
birthday 10/98, not sure if it has the cdl
did all of my research before the purchase
$1600, has 116000 miles, automatic.
But alas, I didnt just get the truck alone. I got 3 amigo's and a misfire.
I will be doing the abs mod, I have to order the "amigo" code reader before I do anything. The misfire should keep me occupied
No valve tap, or engin rattle of anykind.
Looking to do a mild lift and drive for a year to see if it stays in the stable
I am looking for the best service manual. If some one could give me the lowdown on that I would appreciate it.
Will post pics at some point. TTFN
pinion is offline
post #2 of 7 (permalink) Old 04-20-2017, 11:03 AM
Quoted: 290 Post(s)
Welcome
You don't need anything other than the part. The code reader is helpful if replacing the switch module doesn't solve your problem, but you don't need it- yet.
Misfire is likely the plug wires. They're not easy to replace so many neglect them. Instead of the ABS tool, you'd be well-served to get a decent scan tool.
Skip the lift for now. You've got about $1k worth of work to do on remedying the neglected maintenance the truck has right now.
best service manual is the factory one. It's called RAVE. I think this is the only place that still has it up. Resource is offline RAVE Workshop Manual | MyRangeRover.co.uk
pinion likes this.
CT090 is offline
post #3 of 7 (permalink) Old 04-20-2017, 12:22 PM Thread Starter
Quoted: 4 Post(s)
Originally Posted by CT090 View Post
Welcome
best service manual is the factory one. It's called RAVE. I think this is the only place that still has it up. Resource is offline RAVE Workshop Manual | MyRangeRover.co.uk[/url]
Thanks, misfire cleared up. truck has sat for awhile, and new plug wires. Yes I know about the entire fluid change for every wet in the vehichle. this is just a 3rd car, with the intention of lifting and light wheeling. I have a good scan tool, but wont clear the codes for abs.
pinion is offline
post #4 of 7 (permalink) Old 04-20-2017, 12:49 PM
Drives like an old man
discomania04's Avatar
Quoted: 31 Post(s)
Garage
May I recommend the Foxwell nt630 for ABS and SRS. Great tool, not expensive and will activate the ABS pump for bleeding. And of course, it clears those 3 Amigos codes. I just used mine to look at my 3 Amigos and found my shuttle valve has failed. So I got that going for me.
pinion likes this.
2004 Disco II, bone stock, daily driver (gasp!)
discomania04 is offline
post #5 of 7 (permalink) Old 04-20-2017, 01:35 PM Thread Starter
Quoted: 4 Post(s)
Just checked it out, thanks for the suggestion
pinion is offline
post #6 of 7 (permalink) Old 04-20-2017, 04:13 PM
Quoted: 290 Post(s)
Make sure to address the cooling system issues and the front U-joints. If you're lifting you probably need to deal with the flex coupler in the rear too. Dont forget to replace the rubber brake lines with the longer stainless pieces with the lift
CT090 is offline
post #7 of 7 (permalink) Old 04-20-2017, 04:31 PM Thread Starter
Quoted: 4 Post(s)
I will surf the forum for the cooling system issues, non so far. planned on replacing water pump, thermostat, radiator hoses are good.
And yes on the lift, not my first rodeo there.
thanks
pinion is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Checking in from Milwaukee World Traveller Discovery Series II 5 07-21-2014 07:03 AM
Checking in CPT America New Member Introductions 1 12-08-2010 06:22 AM
Checking Brakes sumosino Discovery Series II 4 02-03-2007 05:19 AM
You may post new threads
You may post replies
