Old 12-13-2005, 09:58 AM   #1 (permalink)
troverman's Avatar
Default Not engaging gears!
Sometimes our 2000 SII Disco doesn't go into gear despite the lever being in either Drive or Reverse, and instead rolls down any incline its parked on and revs like its in neutral! It doesn't do this all the time, and when tranny dies engage gear, it works perfectly.
Current:
2005 Land Rover LR3 V8 SE w/ factory winch
Also current:
1995 Mercedes-Benz E320 Wagon
2002 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
1982 Volvo 240 GL Diesel
Previous Rovers:
1995 Range Rover 4.0SE
Old 12-13-2005, 02:27 PM   #2 (permalink)
Sounds like it is time to have the tranny checked for codes and or a service. How many miles on the truck, how long since it has been serviced???
Mike J.
Old 12-13-2005, 02:54 PM   #3 (permalink)
Rocky Mountain High
Funrover's Avatar
Fluid level?
Old 12-14-2005, 07:58 AM   #4 (permalink)
troverman's Avatar
Truck has 94k, just purchased, it is very cold here so no time to check tranny fluid, but I will this weekend. Trans is flawless once it get into gear; doesn't have the problem most of the time.
Current:
Also current:
Previous Rovers:
Old 12-14-2005, 10:06 AM   #5 (permalink)
I would make a point of servicing the tranny, don't worry about the level of the fluid. Consider adding some Lucas tranny additive, will make a nice difference.
Mike J.
