Old 07-17-2008, 07:08 PM   #1 (permalink)
Default O2 sensor
My name is Eric I am from Northeast MO, new to land rover and to this forum. Just bought an 03 disco SE7 59,000 the service engine light is on. codes PO134, PO135, PO155. Took it to autozone and replaced the O2 sensor under the driver side before the cat with a bosch. Autozone then cleared the codes they came back as mentioned above. Also I have both valve covers leaking just a little. Can anyone help
03_disco_mo is offline   Reply With Quote
Old 07-17-2008, 07:38 PM   #2 (permalink)
It is early to see so many 02 codes, what are the exact codes that came back?
As for the v/c gaskets, try tightening them a little them go power scrub your engine and see if the leak stops.
Old 07-17-2008, 07:44 PM   #3 (permalink)
These are the codes that autozoe printed for me.
PO134 HO2S 11 circuit condition(heated oxygen sensor bank 1 sensor 1) PO135 HO2S 11 heater condition (heated oxygen sensor bank 1 sensor 1) PO155 HO2S 21 heater condition (heated oxygeh sensor bank 2 sensor 1)
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 08:00 AM
obd two codes Rovin4life Discovery Series I 4 12-25-2006 10:16 AM
0BD 2 code list Rovin4life Range Rover P38, Mk III and Range Rover Sport 1 12-19-2006 07:43 PM
Compilation of Engine Codes? Sign Guy Range Rover Classic 3 12-19-2006 01:55 PM
Oxygen Sensor replacement - 1991 Range Rover glenncof Range Rover Classic 1 08-04-2005 06:28 AM
