Old 12-14-2005, 07:14 PM   #1 (permalink)
Default OBD II Codes - what do these mean?
Hello all you range techs! The Disco II is throwing the following codes
6525
0734
0007
9800
I bought a cheap OBD II code reader off eBay, and these are the numbers it shows. It cleared them once, and I rechecked when it threw the check engine light again.... all four codes.
Only one shows up in the OBD II code book (0734 incorrect 4th gear ratio???)
What do these all mean???????????
////M
////MPower is offline   Reply With Quote
Old 12-15-2005, 11:02 AM   #2 (permalink)
you got some screwed up codes.
the only one that we commonly see is the 0734 its associated with the lean codes thrown by a bad MAF.
I bet five bucks its a MAF sensor.
Old 12-15-2005, 07:26 PM   #3 (permalink)
Beez the truck runs great, what are symptoms of a bad MAF? It passed emissions a month ago and it has a great idle and at all throttle positions.
99 model with 57,000 kilometres or 37,000 miles or so.
Old 12-15-2005, 10:29 PM   #4 (permalink)
When it fails, the transmission tends to shift a little differently, you may smell rich exhaust and can hesitate from a stop. My 99 has the same problem, luckily the unit is not too expensive.
Mike J.
Old 12-15-2005, 10:35 PM   #5 (permalink)
Elephantitis penisitis
Try to clean it first.
Old 12-16-2005, 04:12 PM   #6 (permalink)
Thanks you guys!
I will get a real mechanic to put a higher quality OBD code reader on it and I will post the results for all to see!
Old 12-20-2005, 01:11 PM   #7 (permalink)
Default update
as an fyi:
on a snap-on diagnostics device, the 0734 code came up... fourth gear out of ratio!
still no explanation what that means but it goes to a shop next week for a guru to diagnose and explain.
////M
Old 12-21-2005, 07:10 AM   #8 (permalink)
Default Dirty MAF?
I found a thread on Discoweb, and a cleaning of the MAF may be in order. Strange but true, and I will post the results to see if the clean MAF element will clear the code once and for all.
////M
Old 12-21-2005, 09:57 AM   #9 (permalink)
////M
I have a one code for a MAF failure, went out and got some good contact cleaner from Radio Shack. It did clean all the crude from the sensor, improved the power but I still have a flat spot from a stop and some shifting problems and I can still smell some bad exhaust all of which is typical with a bad MAF.
By the way, cleaning or replacing will not turn off the check engine light, you'll still need a scanner.
The good new is Atlantic British has a good price, around $140, for a new MAF.
Mike J.
Old 12-21-2005, 08:09 PM   #10 (permalink)
Mod. --- I'm watching you
darkknight1999's Avatar
Its the sensor. I had the same thing. If you try and clean it be very careful. Use a good electronics cleaner.
-John
Some of my favorite quotes:
"what you do in life, echo's in eternity..."
"death smiles at us all... all a man can do is smile back..."
1999 Discovery II SE-7
darkknight1999 is offline   Reply With Quote
Old 12-22-2005, 03:58 PM   #11 (permalink)
Default Clean as a whistle!
Well another check showed 8007, 8104, 9200, 6521 and 1400. (no 0734)
Weird, only the 1400 code mase sense and if it was 0104 it would be a MAF.
I started to look for a crack in the intake.
Well I took the entire intake apart. Banged out the air filter and a cloud of dust came out. The snorkel behind the MAF was damp with the combustion chamber/throttle body cleaner I used last week and the barrel shaped reservoir attached to it had a bunch of dirty fluid that had run down and pooled in it from the cleaning. (my carelessness)
Took the MAF off and sure enough you can see the microfine dust particles that make it past the air filter. On the hot-wire you could see the discoloration from the accumulation of brown dust, as well as in the channel the air runs through past the wire. (very slight but a light covering)
I cleaned the wire CAREFULLY with electronic contact cleaner and wiped as much dust off the entire MAF as possible.
I also found a wee split in the plastic where that reservoir attaches to the neck of the intake tube. I glued and ran a bead of silicone around the seal.
So far so good, no codes and it still runs beautifully. Wish us luck!
Thanks for the help with code 0734 !!!!!!!!!!!
Old 12-31-2005, 03:35 PM   #12 (permalink)
Default Might be the solution
The consensus from a few mechanics is that the computer thinks the third to fourth shift might be sluggish at some point.... throwing the 0734. No luck with the MAF sensor, it just runs even better and smoother now!
////M
Old 12-31-2005, 05:41 PM   #13 (permalink)
Did you ever replace the MAP sensor?
-John
Old 12-31-2005, 08:30 PM   #14 (permalink)
Default Nope!
The truck only has 57,000 km (38,000 miles).
I cleaned the hot wire on the MAF and it is perfect. The truck runs perfect and I mean, perfect.
Maybe when I can see what all it takes for a dealer service I might have the tranny fluid changed and make sure the latest software is in the computer. It might just be a glitch.
////M
