ODBII Codes, Which Sensor? - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 03-08-2011, 08:12 AM   #1 (permalink)
DevilDoc's Avatar
Default ODBII Codes, Which Sensor?
I have had a very little experience with readers before, and just bought one for myself. After reading many posts, I ordered the ScanGaugeII. I am a little unclear about something. If a sensor is having issues, will the scanner tell me which one, or does the code itself indicate with sensor is at vault?
For example:
P0171
Oxygen Sensor System Too Lean Fault Bank A
Does 'Bank A' indicate which sensor it is; its location?
Nickel
99 DII / 4.6 / OME 2 " Lift + Heavy Duty Springs / CDL / ARB Air Front and Rear / Viair OBA / Rovertym Sliders / Rovertym Slimline front bumper / Greg Davis slimline rear / Tom Woods Front drive shaft / Cooper Discoverer 285/75 R16
I drive a Land Rover...so most of the time, I don't drive a Land Rover
DevilDoc is offline   Reply With Quote
Old 03-08-2011, 08:25 AM   #2 (permalink)
Bank A = driver's side, bank B = passenger side.
Bosbefok is offline   Reply With Quote
Old 03-08-2011, 08:26 AM   #3 (permalink)
DevilDoc's Avatar
Thank you!
Nickel
Old 03-08-2011, 08:31 AM   #4 (permalink)
tyl604's Avatar
P0171 is the front O2 sensor on the driver's side. It is in front of the cat.
tyl604 is offline   Reply With Quote
Old 03-11-2011, 03:01 PM   #5 (permalink)
hontsi's Avatar
i found this and it's been helpful
Land Rover Discovery II: Proprietary OBDII Codes > Northwest Overland Society > Most Recent
hontsi is offline   Reply With Quote
Old 03-13-2011, 07:38 PM   #6 (permalink)
aka pi
kcabpilot's Avatar
Had the same problem a few months ago and I couldn't find anything in the manual that definitively told me that bank 1 was the left side. I mean, I assumed it was but considering it's a British truck and they drive on the opposite side of the road I just couldn't be absolutely sure. In the end I decided that since O2 sensors have a specific lifetime it would probably be smart to change both forward sensors at the same time. The rear sensors I left be as they seem to have a longer life expectancy, being after the cat.
things are not as they seem - nor are they otherwise
kcabpilot is offline   Reply With Quote
Old 03-14-2011, 11:08 AM   #7 (permalink)
DevilDoc's Avatar
Thanks all. The code above was just an example regarding sensors in general. I was actually pulling misfire codes which turned out to be a wet coil or wires. You can also use: OBD II Codes* MuddyOval.com
Nickel
Got my ODBII Scanner Rover_Goose Discovery Series I 6 04-06-2010 05:52 PM
02 Sensor Codes mtnance Discovery Series II 32 06-28-2009 09:44 AM
Cause of O2 Sensor Codes? lipadj46 Discovery Series II 10 06-13-2009 06:30 PM
98 disco o2 sensor codes lovehateskates Discovery Series I 6 12-03-2008 02:30 AM
TPS Sensor Codes Horseshoe Discovery Series I 1 09-15-2008 07:07 PM
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
