Old 11-07-2007, 06:52 PM   #16 (permalink)
HMBRover's Avatar
You can also get the instructions from Land Rover Owner Information at the link:
http://www.ownerinfo.landrover.com/e...prod/index.jsp
Enter the menu choices for Discovery II and Accessory Fitting Instructions
Look for "Protection Bar - Wrap Around"
I have the same bar on my G4 without the headlamp wraparounds so if you need detailed pictures let me know. I've had it off several times. It appears you have to drill two large holes in the OE bumper and then another hole inside; then a nutsert is intsalled to mount the bar to. Two of the three grill bolts under the bonnet are also replaced with nutserts to attach the upper tabs.
HTH
Brian
2004 Discovery II G4 Edition
2002 Freelander SE - Gone!
Formerly HMBFreelander
HMBRover is offline   Reply With Quote
