Old 10-25-2007, 11:01 AM   #1 (permalink)
Default OEM Pushbar/Grill guard
I just recently picked up a oem factory pushbar/ grill guard to put on my 2003 disco, my question is how do these install? The push bar has two big bolts coming out of it but no spot in the bumper to put them? do I need to put holes in my bumper? any help would be appreciated, thanks...
Witzel is offline   Reply With Quote
Old 10-25-2007, 05:16 PM   #2 (permalink)
'99 Disco II
wimp's Avatar
push bar is a misnomer
don't push anything with it....trust me!
'99 Disco II
ACE / 2" OME lift
245 75 R16 Greatyear MT/R's
wimp is offline   Reply With Quote
Old 10-27-2007, 11:57 AM   #3 (permalink)
Is it an "A" bar?
scottagnew101 is offline   Reply With Quote
Old 10-27-2007, 01:39 PM   #4 (permalink)
A bar? not quite sure what an a bar is. The one I have is kinda molded rubber its factory, has land rover all over it. even a part number, but I can not seem to locate any information for installation anywhere, the push bar covers the entire grill along with the lights, there are to big screws that go into the bumper and clips that clip to the to screws on the radiator and screw on the bottom of the headlights, the clips match up everywhere except for the bolts which there is no spot in the bumper, so my question kinda is do I need to drill holes in the bumper to install this, is there going to be something back there to put the screws into?
Old 10-27-2007, 02:39 PM   #5 (permalink)
It could be an a bar if I took off the light protectors. The are two big bolts with sleeves to install, just wondering how to do it? if anyone has done it, and if I need to drill holes?
Old 10-28-2007, 12:47 PM   #6 (permalink)
Searcaigh's Avatar
Gallery: 31
Post a pic so that we know exactly what you are talking about
Gordon T. Smith
Middle East Land Rover Nutter
Searcaigh is offline   Reply With Quote
Old 10-28-2007, 02:17 PM   #7 (permalink)
My bar is factory with factory light tabs. It even says "DISCOVERY" Its metal, with a plastic/rubber coating. It does not protect on the sides just the middle. It is also made from tube. If this is what you have ill take a look and let you know how it connects on.
Scott
Old 10-30-2007, 09:54 AM   #8 (permalink)
Default push bar/brush bar pics
here a couple pictures of the grill guard/push bar that I'am trying to install. It has two long bolts as pictured w/ sleeves that go through one of the holes as pictured as well, then there are two clips both on bottom of grill guard and the sides that just attach to the radiator screws and underneath the bottom of the headlights some how. I just don't know how the screws attach, there is no hole in the bumper, I think i have to drill a hole, put if I drill I want to make sure that there is something back there to put the the screws into some I'm not cruising around with a couple of nice holes in the bumper and no brush bar on there.
I' am trying to install this onto a 2003 discovery S. any suggestions or advice is welcome. thanks.
Old 10-30-2007, 09:55 AM   #9 (permalink)
Default pics
opps, here are the pictures.
oem-pushbar-grill-guard-rover1.jpg  oem-pushbar-grill-guard-rover2.jpg  oem-pushbar-grill-guard-rover3.jpg
Old 10-30-2007, 11:45 AM   #10 (permalink)
'00 DII Member
auwesman's Avatar
Where'd you get it exactly. Looks like it's used, did it come off a DII?
'00 DII
'07 Toyota Taco
War Eagle!
auwesman is offline   Reply With Quote
Old 10-30-2007, 01:16 PM   #11 (permalink)
He did what in his cup???
DevilDisco's Avatar
That's a polyurethane Brushbar or the 2003-2004 DII only, been looking for one of those (on the cheap). That can't be all the monting hardware. That must be really light and a good place ot mount driving lights. Hate to say it but it looks like some drilling is required.
'04 Discovery SE7. Last of the best.
DevilDisco is offline   Reply With Quote
Old 10-30-2007, 10:01 PM   #12 (permalink)
Yes I bought it used, it come off of a 2004 D2.
It so extremely light. Thinking about mounting some lights. not sure yet though
Old 10-31-2007, 11:14 AM   #13 (permalink)
DevilDisco's Avatar
Perhaps you should call Rover Connection. They are the only ones I know of that sell the Poly Urethane Brush Bar. They sell the mounting hardware as well so if you're missing something they would be able to tell you and possibly give you some general instructions about how it attaches to the vheicle.
Old 11-03-2007, 01:32 PM   #14 (permalink)
I tried emailing rover connection for some help no reply from them.
Old 11-04-2007, 05:17 AM   #15 (permalink)
discofacelift's Avatar
Hi Witzel,
I've just had a look at the rave CD and it gives you the fitting instructions in a picture diagram format.
If you don’t have a copy you can down it free from this website
When you’ve down loaded the file you will have burn it on to a CD your self and write is as an image file. You will then have the exact same maintenance CD the dealers use.
The Discovery 2 is the rave CD 1 the 3rd down the list.
http://green-oval.com/joomla/index.p...d=13&Itemid=29
Hope this helps
discofacelift is offline   Reply With Quote
