Old 05-07-2006, 03:05 PM   #1 (permalink)
Default OEM trailer harness???? special????
Is there anything special about the OEM trailer harness??? Or will an aftermarket one work just as well??? Does the OEM one allow for electric brakes without a complete re-wire???thanks, Dean
6cuda6 is offline   Reply With Quote
Old 05-07-2006, 03:17 PM   #2 (permalink)
Dean, I think you will have to wire in your brake unit still. As for aftermarket or factory, if you are using a trailor with more then one set of lights go factory or you won't have enough voltage to drive all the lights.
Old 05-07-2006, 09:05 PM   #3 (permalink)
Rocky Mountain High
Funrover's Avatar
yo can put aftermarket on...but not worth it!!
Old 05-08-2006, 03:42 AM   #4 (permalink)
Angel of Death's Avatar
I picked up the OEM-style (plugs right into the truck) from British Atlantic. Someone on here suggested it to me. $107 shipped the next day to my father's house.
Angel of Death is offline   Reply With Quote
Old 05-08-2006, 08:03 AM   #5 (permalink)
I was the one who suggested your purchase, you will like it. When are you getting out of the servie?
Old 05-08-2006, 09:13 AM   #6 (permalink)
ChuckD's Avatar
Default No trailer provision.
You will find no wires for railer brakes in the package. The only hard part of a brake installation is running a fairly high-capacity 12vdc wire from the front of the truck. Suggest tying in at the battery with an independent fuse or circuit breaker. There's also an issue of getting wires in and out of vehicle interior. Routing wires must be done with care if you run themunder the vehicle. Good luck.
ChuckD is offline   Reply With Quote
Old 05-08-2006, 02:19 PM   #7 (permalink)
Hi Mike! I thought it was you! Thanks again for the suggestion! My old man said it should take about 4 minutes to wire up. Great kit he says!
I'm out of Bolivia first week in Dec and out of the Marines first week in January. I can't wait! My truck will have about 500 miles put on it in its first year and then 3000+ the first week of the second year. I hope she doesn't break down towing a Uhaul trailer! That would sucks so bad.
Erik
Old 05-08-2006, 03:37 PM   #8 (permalink)
Otherwise known as STEVE
You could have saved yourself a lot of money by buying a $17 Hoppy at Wal Mart instead- it's the same thing except they added a plug. Without the plug, it takes 3 minutes more to install. The REAL problem is that the AB/Hoppy solution can't deliver enough power to run more marker lamps than what a small utility trailer would have. If you tow something with several marker lamps, you'll ruin the Hoppy box and possible damage the computer in the Rover. The Genuine kit can handle the current draw of larger trailers.
I learned this the hard way- hotwiring the trailer marker lamps to a 12V battery on the side of the road in the middle of the night so I'd have some lights working.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 05-09-2006, 10:39 AM   #9 (permalink)
I don't care how much I wasted in $$. I just wanted to make installing the kit as easy as possible for my father who's nice enough to store my truck while I"m serving overseas. Ah well.
Old 05-09-2006, 12:19 PM   #10 (permalink)
Well, the plug does make it easier- you might want to give him a quick 'heads-up' about keeping the current draw on the trailer low... if it has clearance lamps in addition to the lower corner markers, he should disconnect them or re-wire them to a constant 12v feed using an RV plug.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 G4 Disco
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1973 SIII 88
