Links
Old 03-13-2007, 09:32 PM   #1 (permalink)
scotth's Avatar
Default Off road question
As I have stated in some earlier post I have no off road experience with my Rover. I have had other 4x4's in the past and have been off road with them. My question is when your tires load up with mud on a Disco how do you clean them out? The way I understand the traction control works is it will not let the tires spin to clean out the mud. This my sound like a crazy question but it was just something I thought about. My thinking could be way off and once I do take my Disco off road I may have a better understanding then.
99 Disco 2
Kinversand ACE and SLS with 18's
brushguard and 265/60/18's installed
Hood blackout kit
RTE 2 inch lift
Future Mods:
TJM winch bumper,roofrack
scotth is offline   Reply With Quote
Old 03-13-2007, 09:39 PM   #2 (permalink)
01001010's Avatar
Gallery: 15
A lot has to do with the tread pattern on your tires and the type of mud you're driving through. Being that you're in South Carolina, I'd say you mostly see clay type terrain. Most brand name mud terrains clean out well.
JC...
1965 Series IIa 109 RHD Dsl - Wilks
www.TerraTrekker.com
01001010 is online now   Reply With Quote
Old 03-13-2007, 11:02 PM   #3 (permalink)
rmuller's Avatar
Also airing down your tires a bit allows them to clean out better.. the traction control shouldn't really affect it all too much.
Old 03-14-2007, 12:56 AM   #4 (permalink)
Ian Matthews
p76rangie's Avatar
The traction control still allows the wheels to spin, it just stops it every couple of rotations to give drive to the other wheel.
Old 03-14-2007, 04:04 AM   #5 (permalink)
'99 Disco II
wimp's Avatar
Default Tc
if you feel you must, you should be able to disable TC by brushing the brakes (just a bit) while applying the gas. As others have said, you shouldn't need to do this. Good tires and TC are pretty effective for shedding mud.
happy muddin'
'99 Disco II
ACE / 2" OME lift
245 75 R16 Greatyear MT/R's
wimp is offline   Reply With Quote
Old 03-14-2007, 06:06 AM   #6 (permalink)
Once you get some driving time off the road, you might want to look into doing some sort of CDL hook up so you can put more traction to the ground.
