Oil Change HELP! - Page 2 - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 12-19-2008, 06:53 AM   #16 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Originally Posted by redronin View Post
my strap wrench wont budge th oil filter. too small, too slippery, too extreme an angle to get the right leverage. dont wanna use a jaw wrench and dent the new filter
i put a screw driver through it so it would know not to fck with me.
im gonna look for one of those "cap" wrenches but they look horrible
Curious how you would dent the "new" filter....suposed to be hand tight. Not put on with a wrench. Just fill the new filter with oil and lube the rubber gasket with fresh oil and turn on by hand.
1997 Disco 1
2000 Disco 2
My Rover videos.
http://www.youtube.com/user/btp98w?feature=mhee
Old 12-19-2008, 07:38 AM   #17 (permalink)
oh really? my last car was supposed to be torqued down but it had the paper filter type. thanks for the tip ill get the jaw wrench out for the removal and hand screw her back on
Loving
-2002 FI 330
-2004 disco
Looking
looking for a ducati monster in 620/750/800/900
range 3-4k S(2/4) is a bonus. clean titles only plz
redronin is offline   Reply With Quote
Old 12-19-2008, 04:09 PM   #18 (permalink)
Beach Bum
My strap wrench dented it from the metal bar conected to the strap itself. I used the biggerst screw driver I had for leverage - less effort. Damn filter dented right in, good thing it was the old filter....
brian4d is offline   Reply With Quote
Old 12-19-2008, 04:18 PM   #19 (permalink)
roverich's Avatar
I always heard filters are put on hand tight , and tightened with presure from the motor .
current vehicles : 96 Discovery-1 SE7. stock besides 255-70-r 16 ... SOLD
2000 Discovery-2 SD ...2 in OME 763 and 779 springs factory roof rail extensions , flat rack with 500ff's,hella 500's, .. new heads and head gasket . power steering pump , water pump . 265/75R16 guard dogs
roverich is offline   Reply With Quote
Old 02-04-2013, 04:33 PM   #20 (permalink)
disco biscuit
disco biscuit's Avatar
Default Re: Oil Change HELP!
This is the pump I use from harbor freight on my vehicles now. I bought it to add tranny fluid on my 04 disco...I bought a TDI jetta and the oil is much easier sucked out of the dipstick hole than dropping skid pans etc.. you will need some extra length of tube to reach far enough into the oil pan. It should go i through the dipstick hole longer than the length of the dipstick itself. You should google all this before you do it. The infos easily accessible.
http://www.harborfreight.com/multi-u...ump-66418.html
I dont believe your vehicle has a drain plug for the oil. My 04 aint got a dipstick on the tranny. Some reasoning behind it is sealing the components to prevent water and dirt intrusion. Like I said ,now, I dont pull the plug on any of my vehicles any more its just much easier shoving the hose in there and pumping straight into an empty oil jug.
disco biscuit is online now   Reply With Quote
Oil change - regular or Synthetics? aharbour Discovery Series I 11 09-28-2007 09:18 AM
Transmission fluid change theories Disco Truck Discovery Series I 3 03-09-2007 05:11 AM
PS Fluid Change wimp Discovery Series II 3 03-07-2007 12:30 PM
SEO by vBSEO 3.3.2
