Old 02-22-2006, 09:40 AM   #1 (permalink)
Default Oil Filters?
1999 Disco Ii
Can Anyone Tell Me The Difference Between The Socalled Long Oil Filter And The Short Oil Filter.
Which One Do I Need For My Disco Ii
Thanks,
Mark
GOTMUD? is offline   Reply With Quote
Old 02-22-2006, 10:21 AM   #2 (permalink)
A Fram PH8a (or equivelent)will fit on your engine. Its the same diameter and thread size, but about 2" longer. This gives you more filter area, and a little more oil capacity. If you go with a different filter, make sure you get one with a chech valve (rubber flap in the filter) to prevent drain back when the engine is not running.
O.B. is offline   Reply With Quote
Old 02-23-2006, 01:36 PM   #3 (permalink)
Originally Posted by GOTMUD?
1999 Disco Ii
Thanks,
Mark
You might want to upgrade to a 3001 K&N oil filter which has better filter media, oil will last longer and give you better engine protection.
