Old 05-16-2007, 10:35 PM   #1 (permalink)
Default Oil Leak
So, after reading alot of the threads, I'm guessing an oil leak is pretty common with our lovely babys. Well.. how do I stop it??
I just changed the oil over the weekend, and right before changing it I noticed some oil leaking... nothing big at all.. not even a drop on the ground.
Now, after changing the oil and making sure everything was tight, there are oil marks on the ground....
I heard of head gaskets, valve something rathers...so what do I do??
And if I do need to replace, lets say a gasket or something major, would an extended warranty pay for it??
Thanks a bunch!!
John-Robert
2003 Land Rover SE7
- Stock Hardon Karmon speakers
- Stock Navigation System
- Cold Weather Package
- SLS
- ACE
johnnybob06 is offline   Reply With Quote
Old 05-17-2007, 05:12 AM   #2 (permalink)
John-Roger,
Do you have an extended warranty, if so and if your head gaskets are leaking they would most likely pay to replace them. Most warrantys however don't just replace the regular seals by them selves unless it is part of a repair envolving the replacement of a covered component.
Old 05-17-2007, 12:15 PM   #3 (permalink)
HEy Mike!
I've got an extended warranty.. On Monday my truck will go into the shop.. but it seems like it is leaking everywhere!... There are spots all over the floor, and I park in pretty much the exact same spot on my driveway...
2003 Land Rover SE7
- SLS
- ACE
Old 05-17-2007, 12:19 PM   #4 (permalink)
Extended warrantys for the most part will not cover just oil leaks with the exception of the head gaskets. Most policys are word suc=h that they will only replace a gasket as part of replacing a broken covered component.
Most of those leaks you are going to have to pay for.
Old 05-17-2007, 12:26 PM   #5 (permalink)
Alrighty.... Thanks!!
I will look under the truck and see exactly where it is leaking from..
John-Robert
2003 Land Rover SE7
- SLS
- ACE
