Oil leak - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 15 (permalink) Old 08-09-2009, 03:18 PM Thread Starter
Quoted: 0 Post(s)
Oil leak
I have a 03 discovery with a oil leak. I know I need to clean off the old oil to find the leak, but my question is how do you get the bottom splash guard off? I took the screws out and I tried to move it all around. Is there something I'm missing? I looked in the rave cd and didn't see anything. I could be looking on the wrong stop.
Thanks
Brent
Brent03 is offline
post #2 of 15 (permalink) Old 08-09-2009, 03:31 PM
Administrator
Quoted: 5 Post(s)
You will also need to remove the steering stabilizer. Do yourself a favor and throw the shield away, most of us have years ago, they are too hard to work around and restrict a lot of air flow causing the engine to run hotter.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #3 of 15 (permalink) Old 08-10-2009, 05:17 PM
2004 Disco II Trail Edition
Pipedream's Avatar
Quoted: 0 Post(s)
Have you ever heard of anyone busting off their oil filter with the shroud removed?
"The most fun you'll have at 2 MPH"
Pipedream is offline
post #4 of 15 (permalink) Old 08-10-2009, 05:24 PM
House Trained
Prodigy999's Avatar
Quoted: 0 Post(s)
no
Prodigy999 is offline
post #5 of 15 (permalink) Old 08-10-2009, 05:27 PM
lipadj46's Avatar
Quoted: 0 Post(s)
Do you feel how flimsy that shroud is? Doubt it offers any real protection. Mine annoyed me and it got torn out.
2002 DII 114,000 miles
lipadj46 is offline
post #6 of 15 (permalink) Old 08-10-2009, 05:30 PM
mbrummal's Avatar
Quoted: 0 Post(s)
The bottom of the filter is still above the frame rails.
This site sucks balls.
mbrummal is offline
post #7 of 15 (permalink) Old 08-10-2009, 06:06 PM
Pipedream's Avatar
Quoted: 0 Post(s)
I was thinking about more road debris like tire reads bouncing up and tearing it off. Most other vehicles have them a little harder to access. I have the 4.6 I'm not sue if the 4.0 is any different.
post #8 of 15 (permalink) Old 08-10-2009, 06:17 PM
got mud?
Jupiter Rover's Avatar
Quoted: 0 Post(s)
You can take the shroud off. The oil filter is fine.
Pete
2003 DII CDL equipped
33" Destination M/Ts
Jupiter Rover is offline
post #9 of 15 (permalink) Old 08-10-2009, 06:48 PM
mbrummal's Avatar
Quoted: 0 Post(s)
4.0 and 4.6 are pretty much the same. I wouldn't worry about road debris.
mbrummal is offline
post #10 of 15 (permalink) Old 08-15-2009, 07:15 AM
Quoted: 0 Post(s)
I too have an elusive oil leak in a 2003 Disco. This morning after cleaning and running the engine up, I found the leak is coming from one of the blanking plugs for what would have been an oil cooler line connection. As soon as I let the engine cool enough I will remove the plug and put new sealant on an install.
My question is -- I had heard about front cover cracks on 4.2 at the cooler line interfaces, any history of 4.6 covers cracking at those interfaces with just blanking plugs?
Thanks in advance of the help.
ACKtoAZ is offline
post #11 of 15 (permalink) Old 08-15-2009, 09:15 AM
Quoted: 0 Post(s)
My oil is resolved---I think. After allowing the engine to cool, I proceeded to remove the blanking plug. To my amazement, it was barely finger tight!!!!!
I suggest to all that you verify the tightness of this plug every time you change your oil. 10 days ago I completed a drive from MA to AZ in this truck, would hate to think what would have happened if the plug came out in the middle of Kansas!
ACKtoAZ is offline
post #12 of 15 (permalink) Old 08-17-2009, 08:08 AM
Quoted: 0 Post(s)
Where is the blanking plug? I have a leak somewhere that it appears to be coming from the rear right side of the engine, we thought it was the right valve cover gasket, so he replaced both of the valve cover gaskets and its still coming out somewhere. This all started after my last oil change.
03WhiteDisco is offline
post #13 of 15 (permalink) Old 08-20-2009, 04:20 AM
Quoted: 0 Post(s)
It looks like a bolt with a 22mm hex head right above the oil filter. The oil filter screws into an adapter that looks like a very short 45 degree pipe. About 1.5 inches above the flange where adapter interfaces to the front cover facing the right side of the vehicle you should see the "bolt-looking" plug. Mine was barely finger tight. When you remove the plug. there is a small o ring and a magnet in the end (presumably to pick up metal particles in the oil). I put some Locktite 510 on the oil ring (to help seal it) and Locktite thread sealer on the threads of the plug. BTW, my hex head had a torque stripe on it (presumably from the factory build) so over time, my guess is that it just vibrated loose.
ACKtoAZ is offline
post #14 of 15 (permalink) Old 08-20-2009, 05:07 AM
jycsalas's Avatar
Quoted: 1 Post(s)
It is the one with the yellow marking. This is a top view.
and bottom view. Sorry my engine is dirty.
~Josh
2003 Discovery S (64k miles)
Mods: Oil Pressure Gauge, ScanGaugeII, CDL, Electric CDL Actuator, RoverRacks Rear ladder, Limb Risers, ToddCo Front Drive Shaft, DI Wiper Arms, G4 Upper Rear Lamp Guards, No Amigos since 11/09
Coming soon:
Install Greg Davis rear bumper, Replace 4 ball joints, Replace belt tensioners and pulleys.
For the future:
.... wait and see....
jycsalas is offline
post #15 of 15 (permalink) Old 08-20-2009, 06:44 AM
lipadj46's Avatar
Quoted: 0 Post(s)
Funny, yeah it's filthy, you got the OCD or something?
lipadj46 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
HELP! Strange gearbox leak!? Series 3 guy Series Land Rovers 4 03-24-2009 03:39 PM
multiple coolant leak issues akabaa Discovery Series II 6 06-09-2008 07:44 PM
Range rover P38 weird Oil leak problem pat3d Range Rover P38, Mk III and Range Rover Sport 12 04-26-2008 05:56 AM
What's up with that rover oil leak thing??? Steph Discovery Series II 16 09-02-2007 09:37 PM
craziness with the exhaust leak ealex Discovery Series II 4 05-18-2007 05:41 AM
You may post new threads
You may post replies
