Old 07-19-2008, 04:51 PM   #1 (permalink)
2000 Discovery II
beginer disco's Avatar
Default Oil leak coming from the valve cover
I have a leak coming from valve cover gasket. Looking at it, looks like a big job. I have shade tree mechanic experience working cars. Do you have to take the intake offer? If so, is it real big job.
beginer disco is offline   Reply With Quote
Old 07-19-2008, 09:21 PM   #2 (permalink)
Stupid > Ignorant
Looking through the Rave CD, it looks like it is a lot of work for what you are replacing. You'd have to remove the intake, which will likely to ruin any gaskets that you separate along the way.
Mine leaked a bit, I just decided to tighten the two little bolts that you can see from the sides of the engine; this seems as though it slowed the leak. I haven't driven it long enough to see if it has actually stopped for good.
DailyDrivenTJ is offline   Reply With Quote
Old 07-19-2008, 09:53 PM   #3 (permalink)
2000 Discovery II
I will give that a try. Thanks for the help!!!
Old 07-20-2008, 06:24 AM   #4 (permalink)
How bad is it leaking? Have you tried tightening the v/c bolts, it is quite common to have them loosen up.
Before you start tearing her down, tighten the 2 bolts, that you can see, then power scrub the engine and watch it for a day or so.
Old 07-20-2008, 08:33 AM   #5 (permalink)
Yes and no. It depends on where the leak is (left or right), what type of gasket you wish to use and your level of patience.
The right side of the engine is a doodle. The only points of care is whether you are fitted with the later Rover gaskets (evidenced by a edge of what looks like black rubber around the valve cover edge). If you have these, please take care when removing each gasket that none of the four little dowels at the screws don't fall in. Account for all of them. The second point is never to over torque. The dowels are there, in part, because everyone was overtorquing any gasket used.
The left side valve cover is more difficult as the plenum nose is in the way.
To remove the cover, you will have to at least tilt the plenum. That is done by removing the 6 bolts. I find that that is sufficient enough to tilt the plenum a bit..others take everything off. (and more than double the time for that side)
Now you have options for the gasket you will use. Rover cork, Felpro (much better) or the newer LR gasket with the dowels. In all cases, do not reuse old gaskets.
When you replace the plenum, lightly coat the mating edges with a gasket maker or other RTV (silicone) Use a quick setting one. Wipe off the excess after the plenum is secure.
Lastly, a magnetic screwdriver will make it easier to get the inboard screws in place on the left side.
James
bartell is offline   Reply With Quote
Old 07-20-2008, 12:32 PM   #6 (permalink)
2000 Discovery II
It's not leaking real bad, I give what you suggested a try. Less work I have to do the better. Thank you for help.
Old 07-20-2008, 12:36 PM   #7 (permalink)
2000 Discovery II
It's leaking on the left side, facing the Disco. I am going to try to tighten the bolts and powerwash to see if it still leaks. Can you tell me were the fuel filter is, too? Is it fitted in the gas line from along the frame?
Old 07-20-2008, 01:09 PM   #8 (permalink)
'00 DII Member
auwesman's Avatar
No fuel filter on the DIIs. It is a sock, part of the fuel pump inside the gas tank. Should not need changing.
'00 DII
'07 Toyota Taco
War Eagle!
auwesman is offline   Reply With Quote
Old 07-20-2008, 09:34 PM   #9 (permalink)
2000 Discovery II
Guess what the bolts were loose, just tighten them up. Power wash will be done tommorrow. Hopefully, my Disco will keep from marking my garage like its a litter box.
Old 07-21-2008, 07:16 AM   #10 (permalink)
Stupid > Ignorant
JFYI, those little bolts are meant to be torqued at like 6lbs.ft which is hardly any. I don't see any problem tightening them down more myself; just be careful not to break or strip the bolt.
Old 08-11-2008, 12:47 AM   #11 (permalink)
Texmexdisco's Avatar
I have the same problem going to do the exact same thing.
Texmexdisco is offline   Reply With Quote
Old 08-11-2008, 07:10 AM   #12 (permalink)
Tightening, more then the 6 foot pounds usually will stop the leak. Try it, then power scrub the engine and see what happens.
Valve cover bolt head size? krigsmakten Discovery Series II 2 12-07-2007 10:07 PM
Valve cover gaskets??? 6cuda6 Discovery Series II 10 11-24-2006 04:38 AM
Valve cover gasket stb616 Discovery Series II 3 08-03-2006 11:13 AM
What is the bolt on the valve cover? Helopilot Discovery Series I 1 11-10-2004 11:21 AM
Valve Cover Gaskets? Helopilot Discovery Series I 6 11-09-2004 04:11 PM
