Old 08-26-2008, 07:53 AM   #1 (permalink)
boosoo's Avatar
Default Oil Leak Found - Oil Pressure Switch
I have been trying to track down my leak for sometime. I have power scrubbed the engine on several occasions. I was thinking valve covers, but that was not it. It looks as if it is coming from the oil pressure switch. Is this common?
boosoo is offline   Reply With Quote
Old 08-26-2008, 08:05 AM   #2 (permalink)
Not really, bit if you see yours leaking, it doesn't make any difference if it is common.
Make sure to tighten the 2 bolts, that you can get to for each valve cover, they are common leakers.
multiple coolant leak issues akabaa Discovery Series II 6 06-09-2008 09:44 PM
What's up with that rover oil leak thing??? Steph Discovery Series II 16 09-02-2007 11:37 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
found air bag leak..now how to fix? any experts? national Range Rover Classic 4 12-28-2004 12:33 PM
Problem with the window wipers JP-NORWAY Defender 2 09-02-2004 10:06 PM
