help oil level in engine as indicated by dip stick has increased without me making any additions. Why? suggestions to resolve problem please.I have a series II TD5
Rebuilding Rover
smell the oil does it smell like diesel fuel?
"Only two defining forces ever offered to die for you, Jesus Christ and the American G.I. One died for your soul, the other for your freedom." http://snhlr.org/ 91 Range Rover Classic 90 RRC Parts truck 94 Saab gas mileage beater
#7 (permalink) | |
Jaime from Costa Rica Central America |
Most likely you are getting blow-by with diesel mixing with the oil. Depending on your service schedule (you are changing the oil, correct) decrease the time between oil changes (100 hours max.) Others here know better than I of the needed service checks but really...it's fuel mixing into the oil.
#9 (permalink) |
This is a well known issue with the TD5 engine,if you are lucky it can be cured by changing the unit injector upper O rings and lower copper washers.This is a cheap and easy fix.If you are unlucky and it still rises then its time to have the head off and have the fuel rail pressure tested.The last one I did would raise the level from low to high on the dipstick in 100 miles.
| Thread Tools | |
| Display Modes | |
| [All] Pre 96 OBD1 Fault Codes | TerryS | Tech & DIY | 0 | 01-26-2007 07:00 AM |
| Any body doing electric hybrid in a LandRover? | Adam in NYC USA | Hybrid | 54 | 12-23-2006 10:39 PM |
| P38 ..Non-Starter!! | Fozzy | Range Rover P38, Mk III and Range Rover Sport | 25 | 04-12-2006 03:50 AM |
| Custom fabrication people.. I have a pair of turbos | 02disco2 | Discovery Series II | 9 | 01-24-2006 07:53 AM |
| 99 4.6 is superlocked and won't reset | Spring | Range Rover P38, Mk III and Range Rover Sport | 9 | 12-05-2005 04:46 PM |
