Old 04-26-2008, 08:12 AM   #1 (permalink)
Question oil level increase in engine
help oil level in engine as indicated by dip stick has increased without me making any additions. Why? suggestions to resolve problem please.I have a series II TD5
Haggis65 is offline   Reply With Quote
Old 04-26-2008, 09:40 AM   #2 (permalink)
Rebuilding Rover
ArmyRover's Avatar
smell the oil does it smell like diesel fuel?
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 04-26-2008, 03:02 PM   #3 (permalink)
Fuel or coolant mixing.
Old 04-26-2008, 03:03 PM   #4 (permalink)
ultrrunr's Avatar
or does it taste like water?
Could the water be leaking across, or rather in the heads?
ultrrunr
"Life's Tough, it's even tougher if you're stupid." - John Wayne
ultrrunr is offline   Reply With Quote
Old 04-26-2008, 07:36 PM   #5 (permalink)
Was the vehicle level both times you checked it
tee51397 is offline   Reply With Quote
Old 05-06-2008, 03:01 AM   #6 (permalink)
had oil analysed it contains ~4.0% diesel ? Suggestions to fix problem inexpensively?
Old 05-14-2008, 09:45 AM   #7 (permalink)
I have the same machine and changed the cylinder head because mix the diesel engine with the oil by a fissure in the injector 1.
Jaime from Costa Rica Central America
Jaime Jimene is offline   Reply With Quote
Old 05-15-2008, 07:28 AM   #8 (permalink)
Most likely you are getting blow-by with diesel mixing with the oil. Depending on your service schedule (you are changing the oil, correct) decrease the time between oil changes (100 hours max.) Others here know better than I of the needed service checks but really...it's fuel mixing into the oil.
btharp is offline   Reply With Quote
Old 05-19-2008, 05:39 AM   #9 (permalink)
This is a well known issue with the TD5 engine,if you are lucky it can be cured by changing the unit injector upper O rings and lower copper washers.This is a cheap and easy fix.If you are unlucky and it still rises then its time to have the head off and have the fuel rail pressure tested.The last one I did would raise the level from low to high on the dipstick in 100 miles.
buick215 is offline   Reply With Quote
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 07:00 AM
Any body doing electric hybrid in a LandRover? Adam in NYC USA Hybrid 54 12-23-2006 10:39 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
Custom fabrication people.. I have a pair of turbos 02disco2 Discovery Series II 9 01-24-2006 07:53 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 04:46 PM
