Old 08-28-2008, 04:38 PM   #31 (permalink)
Elemental's Avatar
How cold does your winter get?
When I was done with her, her bed needed Shamwow sheets!
Old 08-28-2008, 04:40 PM   #32 (permalink)
1999 Disco II 'The Rhino' 170,000 miles and going
SafariDave's Avatar
coldest 30's manly in NYC winter is about 40's
The City is a Jungle.
1999 LR Disco II SD The Rhino
1991 RRC (Sold) We will miss the Turtle
1988 RRC (sold)
SafariDave is offline   Reply With Quote
Old 08-28-2008, 06:20 PM   #33 (permalink)
Pinarello's Avatar
Anyone care to post those VIN ranges for oil pump issues? - I also have an '03 DII HSE7 w/Extended warranty. I want to check mine Fo-SHO!
Todd
Good Luck at the dealer, but at least it was not in need of a new engine afterall!!!
Pinarello is offline   Reply With Quote
Old 08-28-2008, 06:59 PM   #34 (permalink)
Has anyone ever taken apart a filter? I would be interested to see how the check valve works. Did not know it had one. Wonder if it works like the heart valve to keep blood from flowing backwards?
tyl604 is offline   Reply With Quote
Old 08-28-2008, 09:32 PM   #35 (permalink)
jmrivera's Avatar
'03 Discovery HSE7 w/ACE and SLS...
jmrivera is online now   Reply With Quote
Old 08-28-2008, 09:49 PM   #36 (permalink)
5w30 and a bottle of Lucas.
tablets is offline   Reply With Quote
Old 08-29-2008, 03:17 AM   #37 (permalink)
Ian Matthews
p76rangie's Avatar
Originally Posted by bartell View Post
I won't argue with you. We use 20W50.
As a matter of fact, I know you will argue with ME, but if you investigate you will find that the engine still uses the same US designed tappets for decades. They were made for 20W50.
James
This topic has been done to death. Well past arguing about what to use. If people want to put water in their engines (5W/30) they can do it based on all the arguments for and against over many threads in this forum.
Old 08-29-2008, 06:53 AM   #38 (permalink)
brian4d's Avatar
Default LR Dealer
LR Greensboro put 5w/30 in my 4.0 after they replaced the valve cover gasket. I asked and that’s what they recommended. As some already know, they also decided to torque down my drain plug to AT LEAST 65LBS. It was an SOB to get it off.. I forgot who was having the problems... Any resolve? Oil Pump? Engine?
Brian Morgan
I bitch because I can, I can because I live in America.
2002 Discovery SE (Stock - No ACE, No SLS)
1995 Nissan Pathfinder SE (Sold)
1999 Chevrolet Cavalier (Red Bullet)
brian4d is offline   Reply With Quote
Old 08-29-2008, 08:03 AM   #39 (permalink)
jmrivera's Avatar
That's me - ...
Dealer didn't call me back last night, so I am waiting anxiously... I don't know what to hope for ...
Old 08-29-2008, 02:52 PM   #40 (permalink)
jmrivera's Avatar
Default Update!!!
So the dealer says it needs an oil pump... I need to send the warranty company a stupid oil change receipt and they will approve the repair and a rental...
I'll post an update when I get more info.!!!!
Everyone have a wonderful and safe Labor Day!...
Jonathan
Old 08-29-2008, 04:00 PM   #41 (permalink)
actually that bulletin only happened suddenly. if the pump was misaligned then when you were driving it happened.
but the failures occured from 12k to just past 50k but I suspect the last I saw at 50k may not have been serviced to begin with.
Old 08-29-2008, 06:26 PM   #42 (permalink)
Pinarello's Avatar
It interests me that the bulletin states the fix to me a new engine! Yet, the dealer in this instance is going to only replace the pump. Rovin' 4 Life...you are the tech...wtfo?
Glad to hear your Rover is right with the world though, mine too is an 03 HSE7 whose VIN falls squarely in the service bracket. I just had my 60K servicing done at the dealer, and if it needed anything, Im sure Rover would have done it. As it was, they replaced some check valve that made my hill decent and ABS lights come on...
Happy Labour Day people!
Old 08-29-2008, 08:46 PM   #43 (permalink)
LOL
Old 08-30-2008, 03:32 PM   #44 (permalink)
oil pump failure means no oil and destroyed engine.
a low pressure oil pump means its on its way out.
put a new pump and away you go.
Old 08-30-2008, 03:52 PM   #45 (permalink)
oh on the td5 from 99 on the oil pump housing bolt will walk out without any noise and destroy the engine. all you can is put a new one in and torque everything.
91 and Oil Light tonyurban Range Rover Classic 3 02-01-2008 08:46 AM
brake light bulb mystery chrisusvi Discovery Series I 3 02-13-2007 10:19 AM
1999 Discovery Light bulb guide darkknight1999 Accessories 3 03-22-2006 10:31 AM
How do I reset the ABS light jsaturnia Discovery Series II 2 01-19-2006 01:09 PM
ot an old one but true ot 75series3 The Lounge 1 11-15-2005 09:08 AM
